学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Messages Won’t Appear When Typing
When typing on the keyboard, the characters being typed do not appear on the screen.
KeyBoard Cleaning Method
Over time keyboards may become dirty with dust or grime affecting the keyboard. A general cleaning with compressed air is all you need to keep your keyboard functioning.
Troubleshooting:
- Hold laptop upside down.
- Blow the compressed air on keyboard approximately 3 - 5 inches away from the keyboard.
- Continue until all or most of the debris is removed.
Keyboard is Faulty
If cleaning the keys does not work and characters still don’t appear, the keyboard has been damaged and needs to be replaced. Click here for a keyboard replacement guide.
Battery Not Holding Charge
When charger is plugged in, laptop does not hold charge and power button does not do anything.
Bad Connections
It is possible that some connections from the battery to the laptop are loose, including the plug to the wall outlet and the adaptor that goes into laptop.
Troubleshooting:
- Make sure the laptop is plugged into a wall outlet.
- Make sure battery adaptor is plugged into laptop charging port.
- Make sure all connections are secure.
Faulty Power Cord
If you plug in your laptop and the charge light doesn't illuminate or battery percentage increases. You may have a faulty charger or changer cable.
Troubleshooting:
- Plug laptop into charging cord and see if charging light comes on.
- If light does not turn on, plug in a different charger.
- If you do not have another charger you can buy one here.
Battery is Faulty
Plug in the laptop to the charger and allow it to charge for 15 minutes. When you unplug the charger and the laptop instantly turns off, the battery is faulty and needs to be replaced. Click here for a battery replacement guide.
Laptop Keeps Freezing
If laptop takes an abnormal amount of time to open basic programs or doesn't respond to basic commands.
Many Applications Open at Once
Sometimes too many applications can be open at once which can cause the system to freeze or laptop to run slower than normal. The simplest way to close out these applications and only run the application(s) that you are currently using.
Troubleshooting:
- Close all applications currently not in use.
- Reset laptop.
- If laptop is still slow, perform a hard reset by holding down the power button until the laptop turns off.
RAM is Faulty
If you turn on your laptop and hear multiple beeps, these beeps may indicate bad ram. If your laptop randomly shuts down or restarts during use, this also may be an indication of a faulty RAM module.
Troubleshooting:
- Look up HP laptop model BIOS beep codes here. If the codes match up with faulty ram, replace faulty RAM module
- Test RAM modules individually, install module one at a time and restart laptop. If the laptop continues to freeze the module is faulty and needs to be replaced. Click here for a RAM module replacement guide.
Dead Pixels on Screen
When the laptop is turned on, the screen shows either one or multiple dark spots or a bright spots on the screen. This can be caused by a number of reasons such as: misalignment, improper cuts, or dust particles on the LCD matrix. The problem has a possibility of not being dead pixels but possibly stuck pixels. Good news is if they are stuck pixels a screen replacement may not be required.
Dust Particles on the LCD Matrix
This problem can be seen as a dark spot that may have different size portions. Basically you have had dust enter you laptop and come to rest on the RGB film layer causing the colors from the pixel or pixels to be blocked.
Troubleshooting:
- Gently shake the laptop in hope that the dust will fall out of the way of the pixels.
How to verify they are not stuck pixels
If the pixels are displaying any color other than black or changes color based on the background it known as a “stuck” pixel.
Troubleshooting:
- Download a software called Pixelhealer here and run imaging software through the laptop to alternate the color patterns.
- Gently massage the pixels with a soft cloth that are not showing appropriate colors. Generally only works with dark pixels due to the lack of electrical contact.
Pixel Misalignment
Misalignment basically means that the computer has had a major shock from being dropped or stepped on, etc. This shock has caused the pixels to move and display light in the wrong direction. Unfortunately, there is no fix for this other than replacing the screen. Click here for screen replacement guide.
Improper Cuts of Components
An improper cut is basically a sub pixel fault or a manufacturing defect caused by the RGB film layer not being cut properly. This is usually a problem that can be covered by a warranty. If your warranty has expired then a screen replacement is required. Click here for a screen replacement guide.
Laptop Not Turning On
Your laptop is plugged into a power outlet and the charger is working properly, the laptop will not turn on.
Display on External Device
In most cases the computer is on, but simply displaying on another external device that is off or not in use. Your laptop could be displaying on a monitor, projector, or television, which can stop the laptop from booting into windows.
Troubleshooting:
- Remove any connections to external displays that may be interfering with the laptop’s start up.
- Restart laptop if display does not appear right away.
External Devices Plugged into USB Drives
Quite frequently, the culprit is a storage card or USB drive still plugged into your laptop when you are trying to start it up. The laptop will try to boot up through the external storage rather than the internal hard drive which can stop the hard drive from booting up properly.
Troubleshooting:
- Remove any external storage cards, USB drives, and discs from the laptop.
- If the problem persists, restart the laptop with these devices removed.
Defective Hard Drive
If the previous solutions have not worked, it is possible that your laptop has a defective hard drive that requires replacement. Click here for a hard drive replacement guide.
0条评论
