跳转到主内容
HP Pavilion 15-cc123cl RAM Replacement
你所需要的
  1. HP Pavilion 15-cc123cl RAM Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure to power off the laptop before proceeding with the guide.
    • Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
    • Eight 5mm screws.
    • Three 10mm screws.
  2. HP Pavilion 15-cc123cl RAM Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-cc123cl RAM Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-cc123cl RAM Replacement: 步骤 2 中的图像 3,3
    • Gently remove the CD-ROM drive by using a plastic opening tool and sliding it out of the laptop housing.
    • Using the opening tool, gently pry open the back panel of the laptop. Slowly work around the edge of the laptop with gentle pressure.
    • Remove the back cover from the laptop.
  3. HP Pavilion 15-cc123cl RAM Replacement, Battery: 步骤 3 中的图像 1,3 HP Pavilion 15-cc123cl RAM Replacement, Battery: 步骤 3 中的图像 2,3 HP Pavilion 15-cc123cl RAM Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
    • Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
    • If you're installing a new battery, you should calibrate it after installation.
    • Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
  4. HP Pavilion 15-cc123cl RAM Replacement, RAM: 步骤 4 中的图像 1,2 HP Pavilion 15-cc123cl RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Release the metal tabs on each side of the RAM module by pushing each tab away from the module simultaneously .
    • The metal tabs secure the RAM stick in place and will allow you to pull the RAM stick up.
  5. HP Pavilion 15-cc123cl RAM Replacement: 步骤 5 中的图像 1,2 HP Pavilion 15-cc123cl RAM Replacement: 步骤 5 中的图像 2,2
    • Once the metal tabs are released, it'll cause the RAM module to "pop" up.
    • Pull the RAM module directly out of its connector.
    • If there are two RAM modules installed, repeat the above procedure for the second module.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 782
