跳转到主内容
HP Pavilion 15-cc123cl Battery Replacement
你所需要的
  1. HP Pavilion 15-cc123cl Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure to power off the laptop before proceeding with the guide.
    • Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
    • Eight 5mm screws.
    • Three 10mm screws.
  2. HP Pavilion 15-cc123cl Battery Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-cc123cl Battery Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-cc123cl Battery Replacement: 步骤 2 中的图像 3,3
    • Gently remove the CD-ROM drive by using a plastic opening tool and sliding it out of the laptop housing.
    • Using the opening tool, gently pry open the back panel of the laptop. Slowly work around the edge of the laptop with gentle pressure.
    • Remove the back cover from the laptop.
  3. HP Pavilion 15-cc123cl Battery Replacement, Battery: 步骤 3 中的图像 1,3 HP Pavilion 15-cc123cl Battery Replacement, Battery: 步骤 3 中的图像 2,3 HP Pavilion 15-cc123cl Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
    • Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
    • If you're installing a new battery, you should calibrate it after installation.
    • Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
结论
另外一个人完成了本指南。
一条评论
Bonjour, please, aidez moi, mon ordinateur HP Pavilion 15 cs00051 ne démarre pas, seule le voyant du bouton d'allumage et le voyant de charge clignotant continue
Spiritus Sanctus - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 4,548
