跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
设备无法开机
雷达设备没有任何反应,或没有显示任何电源开启的迹象。
点烟器适配器故障
确保点烟器适配器已连接,且电源指示灯亮起。如果适配器已连接但指示灯未亮,说明适配器存在故障。建议购买一个新的适配器进行更换。
音频失真或没有声音
雷达发出的声音听起来有静电杂音,或者完全没有声音。
扬声器故障
如果雷达发出的声音失真,或者在应该发出声音时没有声音,那么可能是设备扬声器出了问题。请前往 Escort Radar 9500IX 扬声器更换指南 并按照步骤更换雷达扬声器。
显示屏停留在黑屏状态
雷达的显示屏呈黑色,没有任何显示。
点烟器适配器故障
确保雷达已连接并通电。如果雷达已连接但无法开机,则可能是点烟器适配器故障,需要进行更换。
显示屏故障
如果雷达显示屏没有反应,且始终保持黑屏,说明显示屏已损坏。首先检查显示屏亮度是否已调高。如果亮度已调高但仍然黑屏,则说明显示屏存在故障。请联系 Escort Radar 公司更换你的雷达。
设备无响应
按下任何按钮时,设备均无响应。
版本过旧
你的设备版本可能过旧且已过期,可能无法与车辆连接。请尝试下载最新版本。请前往 如何更新 Escort Passport 9500IX 以更新你的雷达。
Kennedy Morales
于10/20/17注册
664 声望
创作了6篇指南
团队
UMass Dartmouth, Team S2-G3, Peak Fall 2018 UMass Dartmouth, Team S2-G3, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G3
3 名成员
创作了84篇指南
6条评论
My device just took a crap power cord has a light but the device no light and sound
I V - 回复 分享
My Passport 9500i is:
1) No longer marking locations
2) I had to replace the speaker last year. It started blasting unnervingly LOUD in certain interference locations. Not all though.
Any suggestions or solutions would be greatly appreciated.
Tom
raindog264 - 回复 分享
I use my Escort in Europe as well. The Ku-band however, cannot be set. When I check the Ku-band and hit the Change to be saved to the detector it unchecks it. What is the problem here?
Paul - 回复 分享
Any insight would be greatly appreciated.. My device powers on and stays on as well as I can change the functions. The problem is as soon as it senses and goes to alert it immediately tells me to reboot power and stays on that message. I am going nuts because I only have had this device for 3 months and has done this since I received it. Thank you beforehand.
John Doe - 回复 分享
To John Doe:
In my opinion, you need to return it for exchange. That is a faulty unit.
It is too bad that this site is not monitored by the Escort folks and no one reply.
Paul
Paul - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 36
总计 8,353
