跳转到主内容
Crosley 无法开机
按下电源按钮后设备无法开启;红色指示灯未亮起。
未连接电源
确保设备已插入有效的电源插座。
电源按钮未激活
检查电源按钮是否已按下并保持在接通位置,以及按钮旁的红色指示灯是否亮起。
Crosley 没有声音
设备可以开启,但在尝试通过 CD、唱机、卡带、辅助线缆和/或收音机播放音乐时,设备没有声音发出。
音量过低
顺时针旋转音量旋钮,检查音量大小。
线路输入开关处于“Out”位置
如果不使用辅助输入功能,请确保位于设备背面辅助线缆附近的线路输入开关处于关闭位置。
唱机无法转动
设备可以开启,但在将唱机唱臂向右移动后,唱机无法激活/转动。
确保设备左前方的功能切换开关已设置为唱机(phono)模式。然后尝试将唱机唱臂向右移动,直到听到“咔哒”一声。确保已拆下针头保护盖。
CD 无法播放
正确插入 CD 后,CD 会转动但没有声音。
确保设备左前方的功能切换开关已设置为 CD 模式。确保 CD 表面清洁,并已将标签面朝上正确插入。
收音机无法播放
开启设备后,收音机无法调台或发出声音。
功能切换开关模式错误
确保设备左前方的功能切换开关处于收音机模式,并通过设备前方的一个小按钮选择 AM 或 FM 频率。按下该按钮时为 FM 模式,弹出时为 AM 模式。
天线被遮挡/脱落
确保位于设备背面的 FM 天线(一根细导线)没有被遮挡或脱落。移动导线直到听到清晰的信号。对于 AM 接收,本机配有内置的定向铁氧体天线。转动机器以找到最佳接收位置。请勿将 FM 天线导线连接到任何室外天线上。
MarkAnthony
于09/22/13注册
826 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G4
3 名成员
创作了60篇指南
75条评论
My crosley is off the red light not turn on "(
Miad - 回复 分享
My Crosley is working except for the CD player which opens but does not close when you push the button, you have to put the power of and on. The main problem is the display screen, it just turns green, so no words to see what function was selected, e.g. cd or tuner......
Alta la Grange - 回复 分享
So I was messing around with one my grandmother gave to me. She has it in perfect conditions almost never used. I figured out how to start it and then moved more to the right to see if that stopped it. It seems like that broke it as now it wont stop spinning and wont click at all. I got it to stop by wiggling it a little and now it wont start anymore. Any solution?
Marq - 回复 分享
under the table there is what I would call a stiff wire actuator rod that slips into a hole at both ends. one end slips into a hole under the counter weight at back of stylus and the opposite end slips into a hole in the little plastic triangular piece under the table. mine slipped out of one of the holes. perhaps there is someone more educated in turntable nomenclatural linguistics that knows what these items are called and can describe it better than I. you guys know what I'm talking about. help this guy out
Jon b - 回复 分享
My Crosley radio, cd, cassette, etc. works well. However, when I put a record in the sound is incredible low and max volume setting. The needle is new, the volume works really well on every setting except phono for vynil. Any suggestions?
Charlene Romani - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 108
总计 73,017
