跳转到主内容
太好了!你拥有一条线圈拉链。你的拉链头是否可以双面操作,即拉链头可以翻转过来,让你从里面也能拉开?这被称为双向拉链。下面的图片展示了基本线圈拉链(蓝色)和双向线圈拉链(红色)。请选择与你的拉链相符的图片。
基本线圈拉链正面
基本线圈拉链正面
基本线圈拉链背面
基本线圈拉链背面
双向线圈拉链正面
双向线圈拉链正面
双向线圈拉链背面
双向线圈拉链背面
Jake Devincenzi
于04/18/11注册
119,651 声望
创作了57篇指南
2条评论
I have a regular nylon coil zipper, but the back of the slider just has an "A" on it. The puller has YKK stamped, but I can't tell what teeth size it is. help!
Ed Bohl - 回复 分享
Hi @edbohl35755 zips are ususally measured in millimetres. Just measure the across the teeth and you'll likely get something like 3mm or 5mm, these are the standard sizes for coil zippers (at least in Germany, let's hope in the US sizes aren't measured in sixteenths of an inch...). Once you know the size of your zip, you should be able to get a replacement zipper. Hope this helps :)
Maria Parker - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 94
总计 7,032
