跳转到主内容
扳机无法工作
当你按压扳机时,电钻没有反应。
电池未充电
Bosch PS21 无线电钻配备 2 块 12.0 V 2.0 Ah 电池组。如果一块电池没电,请尝试另一块。尝试将其中一块电池放在自带的充电基座上充电 1 小时。如果电钻仍无法正常工作,请给另一块电池充电 1 小时后再试。
电池故障
如果电池无法充电,可能是电池本身出了问题。锂离子电池能量很高,且含有危险化学物质。如果电池出现故障,必须进行更换。请使用此指南。
扳机故障
如果执行上述步骤后扳机仍无法工作,说明扳机可能存在故障,需要更换。请使用此指南。
离合器无法工作
可调离合器无法转动或卡住了。
离合器故障
如果离合器无法工作,则需要更换齿轮箱。请使用此指南。
电池无法充电
电池无法充电。
电池故障
充电器故障
如果更换电池后电钻仍无法工作,说明充电器可能坏了。如果充电器出现故障,必须进行更换。
钻头不转动
钻头转速不够或完全不转动。
电池未充电
电池故障
电机故障
如果执行上述步骤后电机仍无法工作,说明电机可能存在故障,需要更换。请使用此指南。
Daniel Sebastian
于02/15/16注册
145 声望
撰写一个指南
团队
IUPUI, Team 1-2, Harley Spring 2016 IUPUI, Team 1-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G2
4 名成员
创作了48篇指南
7条评论
left my bosch 18 v impact driver out side and it did rain and got wet . i accidentally pressed trigger and turn it on it did worked shortly and then stop and now completely dead.. what kind of damaged i created ? fixable ? any parts should i replace to fix it?
pls help .. thanks kid
rey panelo - 回复 分享
i got the ps21 out of the bins at the goodwill outlet, along with the charger. no battery. i cleaned it up , looked pretty good so i sold it on ebay . fetched a pretty good profit …well without a battery and no test i shouldve kept it ….it didnt work…so the dude sent it back …i found this site …took it apart …cleaned it put it back together twice . installed new battery and works like a brand new one … im sure ill keep it now …handy little devil!!
Kevin Mulkins - 回复 分享
My cordless drill is not releasing the drill bit and, the charger and the charger is working ?
Jim King - 回复 分享
My drill is not releasing the dillbit and the charger is working ?
Jim King - 回复 分享
Good day, I have a gsr 100 bosch 3601 JF4020 10.8V screwdriver machine not charging how do go about it have taken it to the professionals they change the battery abd still not working, when plugged the three lemon light of the battery signal always blinks at the same time and machine still not working, kindly advise on the next thing to do. Thanks
yusuf abiodun - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 82
总计 21,068
