跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
砂纸机无法启动
电源线切断/破损
电源线可能已损坏。检查是否有切口或裸露的电线。
电源开关损坏
电源开关可能已损坏或卡住。这需要你拆解砂纸机并更换开关。
砂纸机只能以单一速度运行或无法变速
变速开关损坏
变速开关可能已损坏或卡住。你需要将砂纸机拆开以更换该开关。
砂纸无法粘附在打磨盘上
打磨盘上的魔术贴磨损/损坏
打磨盘上的钩面魔术贴可能已损坏。你可能需要更换打磨盘。
砂纸机无法集尘
微过滤集尘盒脏污/堵塞
集尘盒可能已堵塞或积满了灰尘。如果集尘盒堵塞,你可能需要清洁或彻底更换它。
更换打磨盘时无法拧紧内六角螺丝
打磨盘螺丝刀接口和/或内六角螺丝滑丝
内部打磨盘螺丝刀接口和/或内六角螺丝可能已滑丝。请更换这两个部件。
打磨盘内六角螺丝在运行过程中无法保持紧固
打磨盘螺丝刀接口和/或内六角螺丝滑丝
5条评论
My sander slows down when I place it on a wood surface
George Wilbur - 回复 分享
Sanding pad is rubbing on dust baffle melting both parts
Clayton Leitch - 回复 分享
Suggest removing sanding pad and pulling dust baffle off to resolve problem.
My girlfriend refinishes hardwood floors professionally, and this is her preference with this machine. She also runs the sander with a shopvac attached instead of the stock dust canister. Be advised that the dust baffle does act as a mechanical brake to slow or stop the sander's rotation. If removed, the sander might act differently than usual. With dust baffle removed, the sander shouldn't be allowed to spin up to high rates of speed without any load. Spinning too fast will cause the sander pad to gouge the surface on first contact after spinning up while unloaded. It also might damage the bearings over time.
Robert Gerber - 回复 分享
When new, the sander comes with a thick grease applied between the dust baffle and the sanding pad. In your case, I imagine this grease has worn away or been saturated with dust. If you want to keep the dust baffle, I suggest finding a very thick grease (preferably nothing that would stain when flung off by the rotation of the sanding pad). Careful grease selection may also be necessary to avoid a type of grease that could damage the rubber of the dust baffle or the sanding pad. Perhaps silicone based grease? As an alternative to grease, you could also try the application of a paste wax product. Johnson and Minwax both make such a wax, for use in woodworking. Suggest cleaning both pad and baffle surfaces to remove old grease and dust prior to applying any paste wax product, as it may not adhere otherwise. Cleaning thoroughly might be less important when adding grease, but is probably wise. Should probably remove sanding pad from sander for this cleaning. Use included wrench slipped under handle assembly.
Both the dust baffle and the sanding pad are available as replaceable parts on ereplacementparts.com and from Bosch directly. I would definitely consider the sanding pad to be a consumable product when under heavy use. Eventually the velcro hooks break off and the thing needs to be replaced. Personally, I'd question how much actual trouble was being caused by this issue and act accordingly. It's my opinion that the dust baffle was poorly designed.
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 43
总计 1,566
