跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的Powerbeats Pro,请使用我们的维修手册
    最后的想法
    • The battery is a fairly common button-cell, and is only lightly soldered in place, meaning battery swaps are technically possible with the right tools.
    • The earbuds’ opening procedure is not totally destructive per se, but it will likely lead to at least some cosmetic damage.
    • The earbuds’ internal circuitry is all connected with fragile ribbon cables that do not detach, so a full disassembly can only be accomplished destructively.
    • The charging case is a nightmarish bucket of glue, making potential battery replacements unnecessarily difficult and destructive.
    可修复性评分
    可修复性10分中得1分
    (10是最容易修复)
Taylor Dixon
于06/26/18注册
67,826 声望
创作了94篇指南
7条评论
Review missed the debris screens in the ear tubes which often get damaged. How to replace possibly.
chronus - 回复
I can’t connect them when they are in the case are connect if I take them out of the case they disconnected. and it says they need to be on and on range help please
Eduardo Gaspar - 回复
So far it is just the case for mine that seems broken - It won’t charge the buds properly. I really don’t mind cosmetic damage if I can replace the case’s battery (assuming that is the culprit). Where might I get a replacement battery? Also, if I used enough care, could I not just cut into the case closer to the battery to get at it from underneath?
Tom Hernandez - 回复
I pushed my mesh in on one of my pods. Is there any fix to just bring it back?
AuxCord Broke - 回复
My volume button is stuck. It will turn up and change songs. However I can not turn down the volume at all. Can I fix it somehow?
Lisa Nikodym - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 119
过去 30 天: 560
总计 41,153
