我的问题
I added a SSD drive to it and replace the optical drive with a new one.
我的修理方法
It went well except i forgot to remove the ir sensor before i pulled out the logic board so it was little bit tricky to put it back inside :)
An unknown cable unplug itself when i put back the logic board. I was lucky enough to look at the tutorial pictures to know where it was plugged before (the one near the optical drive fan slot).
我的建议
Be careful to not unplug the cable in the picture when you put back the logic board because it can get stuck easily in the screw hole of the logic board.
0条评论
