跳转到主内容
« 返回到所有故事
Small Crack in Screen
Daniel -
iPad Air Wi-Fi
故事图片
iPad Air Wi-Fi Front Panel Assembly Replacement
3小时
Very difficult
我的问题
There was a hairline crack across the digitizer.
我的修理方法
This was my first iPad repair. The adhesive holding the front glass/digitizer is stronger than I anticipated. I was not doing something right with the iOpener as it never seemed to warm up the adhesive enough to release. I eventually shattered the front glass using the suction cup (accidentally from the existing crack) and ended up tearing it off piece by piece, being sure to watch out for the sensitive areas pointed out in the repair guide. Once the glass was off, the repair became a breeze! But wow, was that an intense glass removal process! [Half of the screen torn off, pictured above, being extra carful around the cables on the bottom right]
我的建议
Consider a hair dryer to warm up the adhesive around the edges (Instead of /In addition to iOpener).
If the screen is cracked, the tape across the screen definitely helps prevent spiderwebbing--but can prevent the suction cup from getting a good seal.
Be patient!!
iPad Air Screen Digitizer图片
$29.99
« 返回到所有故事
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 581
