跳转到主内容
« 返回到所有故事
Exchanging battery of iPhone 5
guentzel -
iPhone 5
故事图片
  • 图片#1
  • 图片#2
How to replace your iPhone 5 battery
15分钟 - 1小时
Moderate
我的问题
Battery was weak. The iPhone 5 often showed +50% battery status - then, all of a sudden, the OS shut down.
我的修理方法
I followed the very good instruction from the fixit-website (Mac mini A1283 型号内存条更换). The instruction said when removing the display you should pry with the plastic opening tool around the display to loosen the display (steps 6-8). This didn't work with me. I couldn't lift the display high enough to get the opening tool between display and body. But when I finally managed to lift it at the bottom (where the screws were), it came off altogether. Luckily, I didn't pull too hard so I didn't damage the wires.
Another thing was the front panel assembly cable bracket (step 10), see photo. It has curved metal tongues that grab somewhere under the cables. It came off very hard - and it was hard to put it back. I first tried to somehow move the tongues where I thought they should go, but to no avail. Finally, I pressed it tightly down, and the tongues snapped in place. I needed quite a lot of pressure until the tongues "clicked".
我的建议
I had difficulties handling the tiny Phillips screws. Tweezers did the trick.
iPhone 5 Battery图片
iPhone 5 Battery
$29.99
Phillips #000 Screwdriver图片
$5.49
P2 Pentalobe Screwdriver iPhone图片
$5.99
Anti-Static Project Tray图片
$6.95
iFixit Opening Tool图片
iFixit Opening Tool
$5.95
Suction Handle图片
Suction Handle
$2.95
« 返回到所有故事
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 100
