跳转到主内容
加入维修社区 - 创建账户
uAttend bn6000 Fingerprint Replacement
你所需要的
    1. uAttend bn6000 Fingerprint Replacement, Disassembly: 步骤 1 中的图像 1,1
      • Make sure to unplug the device before starting.
      • Flip the device over.
      • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
      询问修复机器人
      添加评论
    2. uAttend bn6000 Fingerprint Replacement: 步骤 2 中的图像 1,1
      • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
      询问修复机器人
      添加评论
    1. uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 1,3 uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 2,3 uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 3,3
      • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
      • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
      询问修复机器人
      添加评论
    2. uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 1,3 uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 2,3 uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 3,3
      • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
      询问修复机器人
      添加评论
结论
To reassemble , follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 42
总计 969
