跳转到主内容
加入维修社区 - 创建账户
ionvac SmartClean V2 Power Button Replacement
你所需要的
    1. ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): 步骤 1 中的图像 1,2 ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): 步骤 1 中的图像 2,2
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      询问修复机器人
      添加评论
    2. ionvac SmartClean V2 Power Button Replacement: 步骤 2 中的图像 1,3 ionvac SmartClean V2 Power Button Replacement: 步骤 2 中的图像 2,3 ionvac SmartClean V2 Power Button Replacement: 步骤 2 中的图像 3,3
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      添加评论
    3. ionvac SmartClean V2 Power Button Replacement: 步骤 3 中的图像 1,1
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      添加评论
    4. ionvac SmartClean V2 Power Button Replacement: 步骤 4 中的图像 1,2 ionvac SmartClean V2 Power Button Replacement: 步骤 4 中的图像 2,2
      • Lift the top shell off carefully.
      询问修复机器人
      添加评论
    1. ionvac SmartClean V2 Power Button Replacement, Power Button: 步骤 5 中的图像 1,1
      • Flip the frame upside down so that the inside faces upwards.
      • Locate the 2 screws connecting the power button to the frame.
      询问修复机器人
      添加评论
    2. ionvac SmartClean V2 Power Button Replacement: 步骤 6 中的图像 1,1
      • Unscrew the two screws connecting the power button to the top shell.
      询问修复机器人
      添加评论
    3. ionvac SmartClean V2 Power Button Replacement: 步骤 7 中的图像 1,1
      • Remove the power button from the shell.
      • Position the power button correctly when reinstalling. The power icon should face the ionvac logo and the house icon should face the front of the robot vacuum.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 24
总计 722
