跳转到主内容
加入维修社区 - 创建账户
ionvac SmartClean V2 Motor Wheel Replacement
你所需要的
    1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): 步骤 1 中的图像 1,2 ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): 步骤 1 中的图像 2,2
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      询问修复机器人
      添加评论
    2. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 2 中的图像 1,3 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 2 中的图像 2,3 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 2 中的图像 3,3
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      添加评论
    3. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 3 中的图像 1,1
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      添加评论
    4. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 4 中的图像 1,2 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 4 中的图像 2,2
      • Lift the top shell off carefully.
      询问修复机器人
      添加评论
    1. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: 步骤 5 中的图像 1,1
      • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
      • Set the cable assembly housing to the side.
      询问修复机器人
      添加评论
    2. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 6 中的图像 1,2 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 6 中的图像 2,2
      • Unscrew the 3 screws securing the motor wheel frame.
      • Dislodge the wheel motor frame from the bottom shelf.
      询问修复机器人
      添加评论
    3. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 7 中的图像 1,1
      • Disconnect the cable attaching the motor wheel frame to the logic board.
      询问修复机器人
      添加评论
    4. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 8 中的图像 1,2 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 8 中的图像 2,2
      • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
      • This will separate the motor wheel frame from the motor wheel assembly.
      询问修复机器人
      添加评论
    5. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 9 中的图像 1,1
      • Unscrew the five screws from the motor wheel assembly.
      询问修复机器人
      添加评论
    6. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 10 中的图像 1,2 ionvac SmartClean V2 Motor Wheel Replacement: 步骤 10 中的图像 2,2
      • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
      询问修复机器人
      添加评论
    7. ionvac SmartClean V2 Motor Wheel Replacement: 步骤 11 中的图像 1,1
      • Remove all but the largest gear to expose the silver screws and washers underneath.
      • Unscrew and remove the two silver screws along with each accompanying set of two washers.
      • Now you can remove the motor from the wheel assembly.
      • To clean the motor, use a soft cloth or alcohol wipe.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 1,051
