跳转到主内容
加入维修社区 - 创建账户
ionvac SmartClean V2 Battery Replacement
你所需要的
    1. ionvac SmartClean V2 Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. A magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
      询问修复机器人
      添加评论
    2. ionvac SmartClean V2 Battery Replacement: 步骤 2 中的图像 1,2 ionvac SmartClean V2 Battery Replacement: 步骤 2 中的图像 2,2
      • Remove the 2 screws that secure the battery door.
      • Lift the battery door to reveal the lithium ion battery.
      • If the battery cover is stuck, use a Jimmy or another prying tool to pry it off.
      询问修复机器人
      添加评论
    3. ionvac SmartClean V2 Battery Replacement: 步骤 3 中的图像 1,2 ionvac SmartClean V2 Battery Replacement: 步骤 3 中的图像 2,2
      • Disconnect the battery by squeezing down on the cream-colored tabs of the battery connectors and pulling them apart.
      • Caution: Be careful when removing the connector, as the part can break if too much force is used.
      • When reinstalling the battery, remember to place it in your ionvac with the white strip facing up. If the battery has two flaps, ensure the flaps are facing up before screwing in the battery door.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Dylan
于09/18/23注册
346 声望
创作了3篇指南
2指南评论
need instructions for installation of battery in TZUMI ion vac smart clean robo vac V4
Eileen Meyer - 回复 分享
need instructions for installation of battery in TZUMI ionvac smart clean robovac V4
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 98
总计 3,665
