跳转到主内容
加入维修社区 - 创建账户
iodyne Pro Data SSD Module Replacement
你所需要的
    1. iodyne Pro Data SSD Module Replacement, Remove Service Panel Screws: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      Anti-Static Wrist Strap
      $7.95
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      询问修复机器人
      添加评论
    2. iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 步骤 2 中的图像 1,3 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 步骤 2 中的图像 2,3 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 步骤 2 中的图像 3,3
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      询问修复机器人
      添加评论
    1. iodyne Pro Data SSD Module Replacement, Unfasten SSD module: 步骤 3 中的图像 1,2 iodyne Pro Data SSD Module Replacement, Unfasten SSD module: 步骤 3 中的图像 2,2
      • Identify the SSD module for replacement and note its retaining screw on the chassis perimeter.
      • Unfasten and remove the retention screw for the SSD module to be replaced using a #2 Phillips screwdriver.
      询问修复机器人
      添加评论
    2. iodyne Pro Data SSD Module Replacement, Remove SSD module: 步骤 4 中的图像 1,3 iodyne Pro Data SSD Module Replacement, Remove SSD module: 步骤 4 中的图像 2,3 iodyne Pro Data SSD Module Replacement, Remove SSD module: 步骤 4 中的图像 3,3
      • Lift the outer edge of the SSD module to a 15° angle from the motherboard.
      • Pull the SSD module up and away from its port to remove.
      • Insert the new SSD module at the same angle, then lower it into position and fasten its retention screw.
      询问修复机器人
      添加评论
    3. iodyne Pro Data SSD Module Replacement, Validate repair: 步骤 5 中的图像 1,1
      • After reassembling the chassis by following the steps in this guide in reverse, verify that the new SSD module is recognized and healthy by launching iodyne from the Applications folder and navigating to the Status tab.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order, then validate that the replacement SSD module is healthy by launching iodyne.app and navigating to the Status tab.
取消:我没有完成这个指南。
另外一个人完成了本指南。
iodyne
于01/01/22注册
462 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 33
总计 604
