跳转到主内容
加入维修社区 - 创建账户
iVIEW-754TPC LCD Replacement
你所需要的
  1. iVIEW-754TPC LCD Replacement, Rear Panel: 步骤 1 中的图像 1,3 iVIEW-754TPC LCD Replacement, Rear Panel: 步骤 1 中的图像 2,3 iVIEW-754TPC LCD Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
    询问修复机器人
    添加评论
  2. iVIEW-754TPC LCD Replacement, Remove Battery: 步骤 2 中的图像 1,3 iVIEW-754TPC LCD Replacement, Remove Battery: 步骤 2 中的图像 2,3 iVIEW-754TPC LCD Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
    询问修复机器人
    添加评论
  3. iVIEW-754TPC LCD Replacement, Camera Assembly: 步骤 3 中的图像 1,3 iVIEW-754TPC LCD Replacement, Camera Assembly: 步骤 3 中的图像 2,3 iVIEW-754TPC LCD Replacement, Camera Assembly: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
    询问修复机器人
    添加评论
  4. iVIEW-754TPC LCD Replacement, Remove Camera: 步骤 4 中的图像 1,2 iVIEW-754TPC LCD Replacement, Remove Camera: 步骤 4 中的图像 2,2
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
    询问修复机器人
    添加评论
  5. iVIEW-754TPC LCD Replacement, Logic Board: 步骤 5 中的图像 1,1
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
    询问修复机器人
    添加评论
  6. iVIEW-754TPC LCD Replacement, WIFI Antenna: 步骤 6 中的图像 1,2 iVIEW-754TPC LCD Replacement, WIFI Antenna: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Gently peel the WIFI Antenna up using a pair of tweezers.
    询问修复机器人
    添加评论
  7. iVIEW-754TPC LCD Replacement, Disconnect LCD: 步骤 7 中的图像 1,3 iVIEW-754TPC LCD Replacement, Disconnect LCD: 步骤 7 中的图像 2,3 iVIEW-754TPC LCD Replacement, Disconnect LCD: 步骤 7 中的图像 3,3
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
    询问修复机器人
    添加评论
  8. iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 步骤 8 中的图像 1,3 iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 步骤 8 中的图像 2,3 iVIEW-754TPC LCD Replacement, Disconnect Digitizer: 步骤 8 中的图像 3,3
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
    询问修复机器人
    添加评论
  9. iVIEW-754TPC LCD Replacement, Remove Logic Board: 步骤 9 中的图像 1,3 iVIEW-754TPC LCD Replacement, Remove Logic Board: 步骤 9 中的图像 2,3 iVIEW-754TPC LCD Replacement, Remove Logic Board: 步骤 9 中的图像 3,3
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
    询问修复机器人
    添加评论
  10. iVIEW-754TPC LCD Replacement, LCD: 步骤 10 中的图像 1,3 iVIEW-754TPC LCD Replacement, LCD: 步骤 10 中的图像 2,3 iVIEW-754TPC LCD Replacement, LCD: 步骤 10 中的图像 3,3
    • Insert a plastic opening tool between the LCD and digitizer on the side of the LCD with the ribbon cable. Use a second plastic opening tool to lift the LCD from the digitizer. Repeat this process on both sides of the LCD ribbon cable.
    • Fully remove the LCD from the digitizer.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Robert Clark
于01/21/15注册
1,065 声望
创作了7篇指南
团队
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 的会员
USFT-BROWN-W15S5G4
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 1,013
