跳转到主内容
iRobot Roomba Edge-Sweeping Brush Replacement
你所需要的
  1. iRobot Roomba Edge-Sweeping Brush Replacement, Loosen the edge brush screw: 步骤 1 中的图像 1,1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: 步骤 2 中的图像 1,2 iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: 步骤 2 中的图像 2,2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
结论
Tobias Isakeit
于03/31/14注册
129,301 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 105
总计 2,180
