跳转到主内容
iRobot Roomba Battery Replacement
你所需要的
  1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: 步骤 1 中的图像 1,1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Battery Replacement, Remove the edge brush: 步骤 2 中的图像 1,2 iRobot Roomba Battery Replacement, Remove the edge brush: 步骤 2 中的图像 2,2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
  3. iRobot Roomba Battery Replacement, Loosen the bottom screws: 步骤 3 中的图像 1,2 iRobot Roomba Battery Replacement, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
    • Those screws are captive screws and therefore not removable.
  4. iRobot Roomba Battery Replacement, Remove the bottom plate: 步骤 4 中的图像 1,3 iRobot Roomba Battery Replacement, Remove the bottom plate: 步骤 4 中的图像 2,3 iRobot Roomba Battery Replacement, Remove the bottom plate: 步骤 4 中的图像 3,3
    • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
  5. iRobot Roomba Battery Replacement, Unlatch and remove the battery: 步骤 5 中的图像 1,3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: 步骤 5 中的图像 2,3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: 步骤 5 中的图像 3,3
    • Use your finger to bend the plastic clip and unlatch the battery.
    • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
结论
2等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
129,301 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 46
过去 30 天: 175
总计 7,471
