简介
先决条件 从后壳上松下电池。
你所需要的
这里有两条胶带将电池固定到位。
将iPod翻转到背面,铝制后壳上。 切勿加热电池。
铝合金外壳不必太烫; 随时使用手指触碰确保不会加热过热。
Instead of a heat gun or hair dryer, I used a rice sock (http://www.wikihow.com/Make-a-Rice-Sock) to apply heat evenly across the entire back of the case while the case still sat upright for me to work on getting the battery loose. It was a lot easier than trying to heat the back of the case, then flip the case over and work feverishly before it cooled.
I'm sure this works, but it doesn't seem like the proper way to do this. I didn't like the feeling of prying on a flimsy battery at all. That's not practical. Instead get some molybdenum wire start it underneath the corners, then wrap the ends of the wire on like 2 pencils then tape them so u dont have to wrap the wire around your fingers because it will hurt lol. then apply heat, i went about 130 degrees is what my infrared gun said. I used a geat gun on low and a good distance away. Then just work the wire down the adhesive obviously lol. This worked out very easily for me and I felt safe and more confident about what I was doing. Good luck.
If you really don’t want to remove the battery, you may lift the mainboard slightly instead and disonnect display, back camera flexes and antenna connector. Then gently pull back camera module out of the seat. This gives you enough room to connect new display and back camera flexes. Back cam module would be hanging while you connect everything that got disconnected. Screw back the mainboard and push camera module to its seat.
要重新组装您的设备,请按照本指南的相反顺序进行操作。
另外一个人完成了本指南。
由衷感谢以下译者:
91%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
This isn't even half of the procedure - the battery isn't even completely removed, much less replaced! Helpful but nowhere near complete.
Yeah, you might have skipped the most critical steps, like glass and bezel removal, desoldering, soldering etc..
Hi, the MPN on that WiFi flex confirms this is not an iPod Touch 6th gen, it is 5th Gen. I am trying to source a 6th Gen WiFi Flex.
Ricky Pohlman - 回复
