跳转到主内容
加入维修社区 - 创建账户
iPod Nano 2nd Generation Display Replacement
你所需要的
  1. iPod Nano 2nd Generation Display Replacement, Case Assembly: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    询问修复机器人
    添加评论
  2. iPod Nano 2nd Generation Display Replacement: 步骤 2 中的图像 1,1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
    添加评论
  3. iPod Nano 2nd Generation Display Replacement: 步骤 3 中的图像 1,1
    • When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
    添加评论
  4. iPod Nano 2nd Generation Display Replacement: 步骤 4 中的图像 1,1
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #000 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
    添加评论
  5. iPod Nano 2nd Generation Display Replacement: 步骤 5 中的图像 1,1
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
    添加评论
  6. iPod Nano 2nd Generation Display Replacement: 步骤 6 中的图像 1,1
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
    询问修复机器人
    添加评论
  7. iPod Nano 2nd Generation Display Replacement: 步骤 7 中的图像 1,1
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack. Be careful, this screw is easily stripped.
    添加评论
  8. iPod Nano 2nd Generation Display Replacement: 步骤 8 中的图像 1,1
    • Lift the bottom bezel bracket out of the iPod.
    询问修复机器人
    添加评论
  9. iPod Nano 2nd Generation Display Replacement: 步骤 9 中的图像 1,1
    • Remove the two Phillips #00 screws from the top of the iPod.
    添加评论
  10. iPod Nano 2nd Generation Display Replacement: 步骤 10 中的图像 1,1
    • The highlighted connector attaches the click wheel and headphone jack to the logic board. This cable must be disconnected from the logic board before continuing.
    询问修复机器人
    添加评论
  11. iPod Nano 2nd Generation Display Replacement: 步骤 11 中的图像 1,1
    • Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
    • Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
    添加评论
  12. iPod Nano 2nd Generation Display Replacement: 步骤 12 中的图像 1,1
    • Use a spudger to push the logic board through the iPod out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
    添加评论
  13. iPod Nano 2nd Generation Display Replacement: 步骤 13 中的图像 1,1
    • When removing the logic board, place the tip of the spudger into the hole where you removed the screw and gently push it out. The crevice will keep it in place and decrease the chance of you damaging your board.
    添加评论
  14. iPod Nano 2nd Generation Display Replacement: 步骤 14 中的图像 1,1
    • Completely remove the display and logic board from the metal casing.
    • When reassembling, ensure that the battery is well seated. If the fit is too tight, the edge of the display will score the inside of the screen window.
    添加评论
  15. iPod Nano 2nd Generation Display Replacement, Display: 步骤 15 中的图像 1,1
    • Use a spudger to gently pry the battery up from the back of the display. Be careful not to put too much pressure on the display with your spudger.
    询问修复机器人
    添加评论
  16. iPod Nano 2nd Generation Display Replacement: 步骤 16 中的图像 1,1
    • Use a metal spudger to carefully pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display. By working from the inside of the display, you won't be able to accidentially pry up the clear plastic shielding.
    询问修复机器人
    添加评论
  17. iPod Nano 2nd Generation Display Replacement: 步骤 17 中的图像 1,1
    • Peel up the orange tape covering the display ribbon cable.
    询问修复机器人
    添加评论
  18. iPod Nano 2nd Generation Display Replacement: 步骤 18 中的图像 1,1
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    添加评论
  19. iPod Nano 2nd Generation Display Replacement: 步骤 19 中的图像 1,1
    • Slide the display ribbon out of its connector and lift the display off of the logic board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
82等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
11指南评论
I also had a white screen. I emailed ifixit support and Brady Cabe suggested I reseat the display connector. That did it!
One hint: when you reverse the steps, you will have to reinstall the top bezel but you don't have to completely reassemble the bottom in order to test it. The earphone plug can be left hanging out (avoiding wear and tear on the fragile ribbon cable) as well as the metal brace and the three screws that hold everything together at the bottom - that reduces the possibility of stripping the screws. In my case, I did strip one of the bottom screws: the screen was broken in a car accident that also bent the case enough to make it hard to get to one of the teeny tiny screws. Even though I stripped that one, I was able to get it out by turning it with a (tiny) straight blade screwdriver: there was enough purchase for that even though the head of the screw does not have much material left.
nick - 回复 分享
I found that a 000 Phillips screwdriver worked FAR better than the 00 for all of the screws. Also, the one I repaired had a surprising amount of adhesive holding the battery down. The square end of the plastic spudger worked well to separate the battery from the rest of the internals allowing it to be rotated down and out of the way.
adamjacob - 回复 分享
No success here. I could not figure out how the black retainer worked in order to release the ribbon cable for the display. I ended up breaking it. I tried to put it back together anyway to see if there was sufficient contact to make it work, but evidently not. Oh well, a $50 lesson. One other tool that is needed here is a jeweler's magnifying glass. Magnified pics in these instructions would also be a benefit. Also, can someone tell me how you're supposed to get that one recessed screw back in place?
albertm - 回复 分享
Spit on the tip of my phillips screwdriver holds that tiny screw on until I can get it started in the hole
gordonhamachi - 回复 分享
I also had a white screen, followed the guide step by step, made the repair easy. I do agre with one of the other comments, a 000 phillips screwdriver worked way way better than the 00.
Shainal Nagar - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 47
过去 30 天: 290
总计 102,053
