简介
Connects the hard drive to the logic board.
你所需要的
在这个步骤中使用的工具:Jimmy$7.95
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
Use a spudger or the tip of your finger to carefully disconnect the orange click wheel ribbon from the logic board.
Peel back the black tape securing the two blue bumpers to the hard drive near the orange ribbon cable.
14等其他人完成本指南。
1指南评论
Does anyone know where I could get an adapter for the mini? like one where i can put an SD card in it and increase the storage size
imnotvrysmrt - 回复 分享
