跳转到主内容
加入维修社区 - 创建账户
iPod Mini Casing Replacement
你所需要的
  1. iPod Mini Casing Replacement, Top Bezel: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    询问修复机器人
    添加评论
  2. iPod Mini Casing Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
    添加评论
  3. iPod Mini Casing Replacement: 步骤 3 中的图像 1,1
    • Lift the top bezel off of the iPod.
    添加评论
  4. iPod Mini Casing Replacement, Bottom Bezel: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
    添加评论
  5. iPod Mini Casing Replacement: 步骤 5 中的图像 1,1
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
    添加评论
  6. iPod Mini Casing Replacement: 步骤 6 中的图像 1,1
    • Lift the metal retaining bracket out of the iPod.
    询问修复机器人
    添加评论
  7. iPod Mini Casing Replacement, Casing: 步骤 7 中的图像 1,1
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
    询问修复机器人
    添加评论
  8. iPod Mini Casing Replacement: 步骤 8 中的图像 1,1
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
    询问修复机器人
    添加评论
  9. iPod Mini Casing Replacement: 步骤 9 中的图像 1,1
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
    询问修复机器人
    添加评论
  10. iPod Mini Casing Replacement: 步骤 10 中的图像 1,1
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
    询问修复机器人
    添加评论
  11. iPod Mini Casing Replacement: 步骤 11 中的图像 1,1
    • Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
    询问修复机器人
    添加评论
  12. iPod Mini Casing Replacement: 步骤 12 中的图像 1,1
    • Continue to pull back on the black plastic tab and use your other hand to press down on the click wheel and begin to slide it out of the iPod.
    • It's important to press down on the click wheel as you slide it out, otherwise the click wheel could be scratched by the iPod's metal casing.
    询问修复机器人
    添加评论
  13. iPod Mini Casing Replacement: 步骤 13 中的图像 1,1
    • Continue to slide the click wheel out until it is free of the iPod.
    询问修复机器人
    添加评论
  14. iPod Mini Casing Replacement: 步骤 14 中的图像 1,1
    • Exterior casing remains.
    添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
4指南评论
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
kolbyhardy - 回复 分享
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
Crystal Haugh - 回复 分享
dude the pod mini is an mp3 player from 2005 it literally does not matter, plus, you probably &&^&@@ up the repair anyways
Memez_idk - 回复 分享
@kolbyhardy He didn't touch your ipod mini. Anything you did to it is YOUR fault, not anyone else's, own your mistakes.
Cactus12 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 40
过去 30 天: 164
总计 30,832
