跳转到主内容
加入维修社区 - 创建账户
iPod 2nd Generation Hard Drive Replacement
你所需要的
  1. iPod 2nd Generation Hard Drive Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    询问修复机器人
    添加评论
  2. iPod 2nd Generation Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    添加评论
  3. iPod 2nd Generation Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    询问修复机器人
    添加评论
  4. iPod 2nd Generation Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    询问修复机器人
    添加评论
  5. iPod 2nd Generation Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    询问修复机器人
    添加评论
  6. iPod 2nd Generation Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    添加评论
  7. iPod 2nd Generation Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Peel up the metallic tape attached to the top of the battery.
    询问修复机器人
    添加评论
  8. iPod 2nd Generation Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    询问修复机器人
    添加评论
  9. iPod 2nd Generation Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 70
总计 19,518
