跳转到主内容
加入维修社区 - 创建账户
iPhone Hardware Isolation
你所需要的
  1. iPhone Hardware Isolation, iPhone Hardware Isolation: 步骤 1 中的图像 1,2 iPhone Hardware Isolation, iPhone Hardware Isolation: 步骤 1 中的图像 2,2
    询问修复机器人
    添加评论
  2. iPhone Hardware Isolation: 步骤 2 中的图像 1,2 iPhone Hardware Isolation: 步骤 2 中的图像 2,2
    • Once the battery is disconnected, remove the screen for the best access to your iPhone's internals.
    • Take a picture of what it looks like before any further disassembly. That way you'll have a record what goes where. You'll specifically want to know where any brackets holding connectors in place go.
    询问修复机器人
    添加评论
  3. iPhone Hardware Isolation: 步骤 3 中的图像 1,3 iPhone Hardware Isolation: 步骤 3 中的图像 2,3 iPhone Hardware Isolation: 步骤 3 中的图像 3,3
    • Take a look at the logic board, and make note of any metal brackets (cowlings) holding connectors in place.
    • Use a Y000 and Philips 000 screwdrivers to remove the screws from any brackets.
    • Remove the brackets from the connectors using ESD safe tweezers.
    • A method for screw and cowling organization is highly recommended so you don't lose anything.
    询问修复机器人
    添加评论
  4. iPhone Hardware Isolation: 步骤 4 中的图像 1,1
    • Disconnect all connectors from the logic board, gently bending the flex cables away so they they aren't close enough to make contact.
    • You can remove components as you like for easier access to others but the more you remove, the more you need to reassemble later. The idea is to limit the number of parts that are in play—not to dismantle the whole phone.
    询问修复机器人
    添加评论
  5. iPhone Hardware Isolation: 步骤 5 中的图像 1,1
    • Once you have disconnected everything, reconnect the bare minimum required to boot up the phone (and know it's booting). In most cases this will mean a display, a battery and either the power button cable or the charge port assembly to trigger boot.
    • For sustained use, all iPhones beyond the X need certain sensor containing parts connected to prevent a reboot after 3 minutes. Make sure you have a known good battery, charge port assembly and power button cable to prevent this.
    • Refer to the SMC Panic Assertion failed page for a more complete list per model.
    • With only the fewest number of necessary parts connected, try to recreate the issue. If your issue has resolved, start reconnecting parts one by one until the issue reappears (be sure to disconnect the battery in between).
    询问修复机器人
    添加评论
结论
Once you have determined which part is the issue, replace it and reassemble your iPhone!
取消:我没有完成这个指南。
4等其他人完成本指南。
Alisha C
于12/04/20注册
43,085 声望
创作了9篇指南
团队
LGBTQ Technicians LGBTQ Technicians 的会员
Community
62 名成员
创作了109篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 26
过去 30 天: 131
总计 3,183
