跳转到主内容
iPhone 8 Battery Disconnection
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 8 Battery Disconnection, Remove the pentalobe screws: 步骤 1 中的图像 1,1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Battery Disconnection, Anti-Clamp instructions: 步骤 2 中的图像 1,3 iPhone 8 Battery Disconnection, Anti-Clamp instructions: 步骤 2 中的图像 2,3 iPhone 8 Battery Disconnection, Anti-Clamp instructions: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 8 Battery Disconnection: 步骤 3 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 3 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 3 中的图像 3,3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. iPhone 8 Battery Disconnection: 步骤 4 中的图像 1,2 iPhone 8 Battery Disconnection: 步骤 4 中的图像 2,2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 8 Battery Disconnection, Heat the display: 步骤 5 中的图像 1,1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  6. iPhone 8 Battery Disconnection, Separate the display: 步骤 6 中的图像 1,2 iPhone 8 Battery Disconnection, Separate the display: 步骤 6 中的图像 2,2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  7. iPhone 8 Battery Disconnection: 步骤 7 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 7 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 7 中的图像 3,3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  8. iPhone 8 Battery Disconnection: 步骤 8 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 8 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 8 中的图像 3,3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  9. iPhone 8 Battery Disconnection, Screen information: 步骤 9 中的图像 1,1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  10. iPhone 8 Battery Disconnection: 步骤 10 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 10 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 10 中的图像 3,3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  11. iPhone 8 Battery Disconnection: 步骤 11 中的图像 1,2 iPhone 8 Battery Disconnection: 步骤 11 中的图像 2,2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  12. iPhone 8 Battery Disconnection: 步骤 12 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 12 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 12 中的图像 3,3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  13. iPhone 8 Battery Disconnection: 步骤 13 中的图像 1,2 iPhone 8 Battery Disconnection: 步骤 13 中的图像 2,2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  14. iPhone 8 Battery Disconnection: 步骤 14 中的图像 1,3 iPhone 8 Battery Disconnection: 步骤 14 中的图像 2,3 iPhone 8 Battery Disconnection: 步骤 14 中的图像 3,3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  15. iPhone 8 Battery Disconnection, Disconnect the battery: 步骤 15 中的图像 1,2 iPhone 8 Battery Disconnection, Disconnect the battery: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
  16. iPhone 8 Battery Disconnection: 步骤 16 中的图像 1,2 iPhone 8 Battery Disconnection: 步骤 16 中的图像 2,2
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
结论
Adam O'Camb
于04/11/15注册
196,940 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 279
