跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
iPhone 7 Plus 后置摄像头的更换
你所需要的
  1. iPhone 7 Plus 后置摄像头的更换, 五角梅花螺丝: 步骤 1 中的图像 1,1
    • 开始这一过程前,请将iPhone电量放至25%以下,电量过高可能使得锂电池在意外情况下更容易起火或爆炸。
    • 在拆解前,确保你的iPhone已经关机。
    • 移除位于手机底部的两颗3.4 mm五角梅花螺丝
    • 打开iPhone的显示屏将导致防水密封被破坏。 所以请准备好新的密封胶。未更换密封胶的情况下重新组装的iPhone将不再具有防泼溅功能。
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 回复
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - 回复
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 回复
    How do you turn off if the screen isn’t responding to touch?
    adam - 回复
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 回复
    Instructions for replacing the seal are here: iPhone显示屏粘合胶的更换
    bester - 回复
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - 回复
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - 回复
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - 回复
    The screw size for those with a screw set is P2.
    Gareth Flandro - 回复
  2. iPhone 7 Plus 后置摄像头的更换, 拆机步骤: 步骤 2 中的图像 1,1
    • 加热 iPhone 的下方可以软化粘合剂,让拆解更轻松。
    • 用吹风机或者准备一个 iOpener 来加热 iPhone 下方大概一分钟,以软化屏幕下方的粘合剂
    How long should I use a hairdryer for?
    Warren Binder - 回复
    I used it until it was hot to the touch but not too hot where you burn yourself.
    gczarny -
    Hey, I just took apart my first iPhone 7 plus today, and it was easier for me to use guitar picks and a magic glass tool. I did tear the home flex on the screen—now I know to be more careful of that on disassembly—-~Katrina of iPad Rehab Microsoldering
    jessabethany - 回复
    First I tried to remove the screen with the hot iOpener, but it doesn’t worked, the day after I putted the Iphone in the sun for a while and then used the hot iOpener, then the screen was easy to remove :-)
    Marc Boon - 回复
    Get a T-shirt add heat to a lil corner of it, with either a hair straighter or an Iron , touch the T-shirt if it’s seems hot but doesn’t burn u hold that lil hot piece of T-shirt against the edge ur trying to pry open , if it’s still not opening add a I’ll more heat,
    www.tertlegerl - 回复
    I don’t think the iOpener was effective at softening the adhesive. Using a suction cup and the spudger is good enough.
    Mac - 回复
    I took a hot water bottle and layed it on the display of the iPhone for a minute, because I did not have an iOpener. That worked for me perfect.
    Michael Maier - 回复
    How can I get all this tools
    Ajibol emmanuel - 回复
    Pour ouvrir mon iPhone 7+ j’ai utilisé un séchoir à cheveux avec modération. Cela a été beaucoup plus facile
    Serge - 回复
  3. iPhone 7 Plus 后置摄像头的更换: 步骤 3 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 3 中的图像 2,2
    • 在前面板的下半部分放置一个吸盘,正好位于Home按钮的上方。
    • 确保吸盘与Home按钮不重叠,以确保吸盘和前玻璃之间能形成密封状态。
    • 如果您的屏幕已经严重损坏,使用透明胶带将其粘好可以让吸盘固定。或者您也可以用非常强力的胶带来替代吸盘。如果这些都失败的话,您可以用万能胶将吸盘和破损的屏幕粘在一起。
    Hi! My suction cup doesn’t work. It won’t strongly suck on my screen. Does anyone have any advice?
    kaiminliu119 - 回复
    Heat it up just a little with a hair dryer make sure it’s flat , let it coo a bit now try it??
    robertread - 回复
    The suction cup you provide sucks. In that it doesn’t hold. Luckily I had a set of heavy duty suction cups from when I worked on my iMac.
    Charles Meitin - 回复
    Moi j’ai utilisé un séchoir à cheveux cela a été beaucoup plus facile pour l’ouvrir , mais avec modération
    Serge - 回复
  4. iPhone 7 Plus 后置摄像头的更换: 步骤 4 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 4 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 4 中的图像 3,3
    • 以固定的恒定拉力上拉吸盘,来使得前面板和后壳之间产生轻微的间隙。
    • 将撬起工具的扁端插入间隙。
    • 固定显示器的防水粘合剂非常坚固; 创造这个初始差距需要很大的力量。 如果你很难打开缝隙,上下摇晃屏幕以削弱粘合剂,直到你可以插入撬起工具。
    • 在向上拉起吸盘的同时,旋转撬起工具以加宽屏幕和后壳之间的开口。
    Be very careful not to pull up with too much force. My screen just shattered while I was pulling up with my suction cup. (There were no previous cracks or chips or anything).
    Benjamin Pounds - 回复
    I’m stuck on this part. I’ve heated the bottom up and attached the suction cup right above the home button, but I can’t pull it apart. I feel like I’m going to break the glass display. Tips?
    whtafrcn420 - 回复
    Someone mentioned above, using strong tape helps .
    MajorCouillon - 回复
    You won’t be able to put the spudger into the gap unless the phone is in a vertical position (speaker side up) in your hands.
    Mac - 回复
    read steps 4-9 before attempting. I cracked my glass because I didn’t
    David Lei - 回复
    My first 7 Plus opening. I pulled up the screen just enough to insert a thin guitar pick at the bottom of the phone to break the adhesive. I didn’t even create a gap as such. I then ran the pick along the sides to continue to detach the adhesive, just like iFixIt show in Step 10 for the top of the phone.
    My screen already had a crack at the bottom, near the home button, so I was nervous about pulling too hard on the screen. It had a screen protector fitted so maybe that helped keep it all together.
    iFixIt’s use of a spudger at the bottom of the phone looked hazardous to me, especially with my damaged screen.
    Big Ed - 回复
    This must be a joke. I’ve been trying for days to pull open the iphone like this. Doesn’t work. I bent the ring on the suction cup trying to pull it off, but nothing happens, no gap, not remote possibility of a pick or spudger getting in there.
    James Osborne - 回复
    Ended up using a blowdryer and a razor blade. Bottom got scratched up, but there was no way that fat plastic spudger was going to fit. I got the razor under the corner, from there worked to middle and twisted with repeatedly adding heat. Lots of heat.
    James Osborne - 回复
    Be aware that there is a small connector, under the home button.
    Herb Adler - 回复
    I found that the edge of the spudger was too thick, so I sanded it down to almost a knife edge. This made it much easier to insert into the gap.
    Herb Adler - 回复
    Use the Opener and a razor blade to cut through the adhesive. It takes about 45 seconds to heat up the Opener in a 1000 watt microwave. Be careful not to damage the thin display ribbon cables on the right side iphone. After you use the razor blade to cut the adhesive on the two sides and bottom you should be able to use the spudger to remove the display screen.
    larrywert - 回复
  5. iPhone 7 Plus 后置摄像头的更换: 步骤 5 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 5 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 5 中的图像 3,3
    • 在iPhone左下角的前面板和后壳之间插入撬起工具的扁端。
    • 沿着手机的左边缘滑动撬起工具,从下方开始朝向音量控制按钮和静音开关移动,来将显示屏的粘合剂破开。
    • 不要尝试将显示器顶部从后壳上撬开,因为那里有塑料卡勾固定,可能会被损坏。
  6. iPhone 7 Plus 后置摄像头的更换: 步骤 6 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 6 中的图像 2,2
    • 将撬起工具从左边取出,再从右下角插入。
    • 从下至上的滑动撬起工具来破开固定显示器的背胶。
  7. iPhone 7 Plus 后置摄像头的更换: 步骤 7 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 7 中的图像 2,2
    • 上拉吸盘来上提显示屏以及打开iPhone。
    • 不要将显示屏提起超多10°,因为沿着设备右边有连接显示屏和逻辑板的细软性电路板。
    The ribbon cable part should be said earlier instead of halfway through
    I just broke one because of it
    BrenX1 - 回复
  8. iPhone 7 Plus 后置摄像头的更换: 步骤 8 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 8 中的图像 2,2
    • 上拉吸盘上的小突块,将吸盘从前面板上取下。
  9. iPhone 7 Plus 后置摄像头的更换: 步骤 9 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 9 中的图像 2,2
    • 沿着手机顶部的边缘开口,使用开启塑料片滑动,以松开最后粘合剂。
    I couldn't find the pick in the tool set, so made my own. Then I found the original in the battery box. %#*@.
    Herb Adler - 回复
    Same thing for me
    Jason Skelton - 回复
  10. iPhone 7 Plus 后置摄像头的更换: 步骤 10 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 10 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 10 中的图像 3,3
    • 将显示屏组件拉到略微远离手机的顶部边缘,使其脱离将显示器固定至后壳上的卡勾。
    • 通过从左侧摆动显示屏来打开iPhone,就像翻开一本书的封底页。
    • 此时,先不要尝试将显示屏完全取开,因为还有一些脆弱的排线仍然连接着iPhone的主板。
    So if I broke the cable that connects the display to the logic board. What replacement part would I need to order now?
    Robert Danson - 回复
    Probably the screen
    Christian Sirolli -
  11. iPhone 7 Plus 后置摄像头的更换, 电池的连接器: 步骤 11 中的图像 1,1
    • 卸下四颗将下方显示线缆保护片固定至逻辑版的三端Y000螺丝:
    • 三颗1.2 mm螺丝
    • 一颗2.6 mm螺丝
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - 回复
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - 回复
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - 回复
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - 回复
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - 回复
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - 回复
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - 回复
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - 回复
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - 回复
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - 回复
  12. iPhone 7 Plus 后置摄像头的更换: 步骤 12 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 12 中的图像 2,2
    • 卸下下方显示线缆保护片
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - 回复
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - 回复
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - 回复
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - 回复
  13. iPhone 7 Plus 后置摄像头的更换: 步骤 13 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 13 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 13 中的图像 3,3
    • 使用撬棒的尖端从逻辑板的插座上撬起并断开电池的连接。
    • 向上轻轻翻开连接器线缆,以防止其意外触碰连接到插座并给手机供电。
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - 回复
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - 回复
    I slipped a small piece of paper under the flap.
    MajorCouillon - 回复
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - 回复
  14. iPhone 7 Plus 后置摄像头的更换, 显示屏总成: 步骤 14 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换, 显示屏总成: 步骤 14 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换, 显示屏总成: 步骤 14 中的图像 3,3
    • 确保电池接口是断开的。
    • 使用撬棒的平端或者指甲以撬开两个下部显示连接器,笔直地从逻辑版的插座上撬起。
    • 若要重新安装连接器,向下按压直到其到位,接着重复按下另一端。请不要按压中部。若连接器未对准,可能会弯曲从而造成永久损伤。
    • 如果你在重新组装手机时有空白屏幕,显示屏上有白线,或部分、完全没有触摸响应,请尝试断开连接并小心地重新连接这两根电缆,并确保它们完全就位。
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - 回复
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - 回复
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - 回复
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - 回复
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - 回复
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - 回复
  15. iPhone 7 Plus 后置摄像头的更换: 步骤 15 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 15 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 15 中的图像 3,3
    • 卸下三颗固定前部面板传感器组件连接器的保护盖的三端Y000螺丝。
    • 一颗1.3mm螺丝
    • 两颗1.0mm螺丝
    • 卸下保护盖。
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    chris west - 回复
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - 回复
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - 回复
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - 回复
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - 回复
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - 回复
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - 回复
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - 回复
  16. iPhone 7 Plus 后置摄像头的更换: 步骤 16 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 16 中的图像 2,2
    • 从逻辑板的插座上断开前部面板传感器总成连接器。
    • 这种按压连接器应该小心避免弯曲损伤。
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - 回复
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - 回复
  17. iPhone 7 Plus 后置摄像头的更换: 步骤 17 中的图像 1,1
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - 回复
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - 回复
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - 回复
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - 回复
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - 回复
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - 回复
  18. iPhone 7 Plus 后置摄像头的更换, 后置摄像头: 步骤 18 中的图像 1,1
    • 移除固定后置摄像头支架的两颗螺丝:
    • 一颗 1.6mm 十字螺丝
    • 一颗 2.2mm 子母螺丝
    • 最好使用专用的iPhone子母螺丝刀头和刀把来移除子母螺丝。
    • 必要时,也可以使用一把小的一字型螺丝刀来替代——小心不要滑脱而损伤周围元件。
  19. iPhone 7 Plus 后置摄像头的更换: 步骤 19 中的图像 1,1
    • 移除覆盖在后置摄像头上的金属支架。
  20. iPhone 7 Plus 后置摄像头的更换: 步骤 20 中的图像 1,3 iPhone 7 Plus 后置摄像头的更换: 步骤 20 中的图像 2,3 iPhone 7 Plus 后置摄像头的更换: 步骤 20 中的图像 3,3
    • 使用 iFixit 撬棒或手指甲将两个摄像头排线插头撬起。
  21. iPhone 7 Plus 后置摄像头的更换: 步骤 21 中的图像 1,2 iPhone 7 Plus 后置摄像头的更换: 步骤 21 中的图像 2,2
    • 使用撬棒的平直端从手机上缘将后置摄像头撬起。
  22. iPhone 7 Plus 后置摄像头的更换: 步骤 22 中的图像 1,1
    • 移除后置摄像头总成。
结论
若想重新组装您的设备,请按照本指南倒序操作。
60等其他人完成本指南。
由衷感谢以下译者:
en zh
77%
Kevin Fu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
428,716 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
12条评论
Has anybody done the replacement of the cameras glass? I need to do it on mine because it cracked but I want to know if I have to add any type of adhesive and if so which kind/brand?
pxolo10 - 回复
Its super easy to do.. I have a guide complete but it has no pictures :(
You can follow this guide.. its kind of the same procedure, all you have to do is take out the old and put the new one in. if it does not stick properly, like it being loose, you can then apply a little bit of super glue or any adhesive.. the phone will not be waterproof/ water resistant tho.
iPhone 6 摄像头更换
nicolay.94 -
i would not recommend superglue (cyanoacrylate). i’ve seen it fogging up nearby surfaces while hardening. could be bad on the lens.
Lorz Lorenz -
Hello. Does anyone know how to replace the rear camera’s flashlight. My iphone 7 plus rear camera and flashlight need to be replaced. Not only the camera itself. I didn’t find the flashlight sparepart itself in this website :(
Andrew Samuel - 回复
Hi. Are there any replacement for rear camera and flashlight component for iphone 7 plus. Because my rear camera and flashlight is not working. And I didn’t find any component in Ifixit. Please help.
Andrew Samuel - 回复
I don't know if you already try it but you should try to replace rear camera first. Is not common that flex to go bad unless is broken or liquid damaged.
Can't find the part tho'.
Germanetti Rosas -
Will the flash still work if I removed the cameras only? Thanks.
Sean - 回复
hallo. mein Kamera wackelt beim video. bei normale Fotos wackelt er nicht. was ist genau defekt komplettes Kamera?
serdar - 回复
Hello, i found a soluziotion for my cam that doesn’t works after phone fell down. Basically it’s a reflow monitored with a termocouple in a oven..
https://youtu.be/WGmfsNJWY5o
Oniyaki - 回复
Hey, my Iphone 7’s rear camera is broken and I need to replace it. I now see that there is a dual camera option… but is my one camera phone equipped for a simple upgrade to such… or should I just stick with the single camera. Thanks, Robert
Robert Thuston - 回复
Hi Robert,
This guide is actually for the iPhone 7 Plus. You’ll want to follow this guide, which is for the iPhone 7.
Arthur Shi -
Will done 👍🏻👍🏻
Barzan Tahir - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 71
过去 30 天: 284
总计 70,908
