跳转到主内容
iPhone 7 Display Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 7 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 iPhone 7 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 iPhone 7 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: 步骤 2 中的图像 1,3 iPhone 7 Display Assembly Replacement: 步骤 2 中的图像 2,3 iPhone 7 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  3. iPhone 7 Display Assembly Replacement: 步骤 3 中的图像 1,2 iPhone 7 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: 步骤 4 中的图像 1,1
结论
4等其他人完成本指南。
Evan Noronha
于02/05/15注册
223,594 声望
创作了168篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 2,665
