当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
用这个指南来更换你的已损坏的听筒
你所需要的
这个步骤还没有翻译 帮忙翻译一下
在这个步骤中使用的工具:Tweezers$4.99-
Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up.
Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
按照这个指南相反的顺序把你的设备装起来
按照这个指南相反的顺序把你的设备装起来
245等其他人完成本指南。
由衷感谢以下译者:
100%
Jiajun Lu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
Be careful not to over-tighten the red screw in step 14, the head of the screw broke of with very little torque applied:( Apart from that minor mishap I worked though the guide in a little over 2 hours, big thanks for a fantastic guide!!!
Hi,
I have an iphone 4s belonging to a friend whos speaker appears to be faulty.
When making calls the recipient sounds extremely muffled to the point of being inaudible.
As a technician I have never encountered an issue before whereby replacing the speaker didnt work.
The main test i performed was to take out the motherboard and place it into the chassis of a perfectly working iphone 4s and yet the problem still persisted.
Reason for the above is because it negates the need to individually test the dock connector and other various minor parts.
My question is where on the motherboard where this problem maybe occuring?
Is it the 2 copper plates that connect the speaker part to the m/b.
Is there any other way I can troubleshoot this?
Any help would be appreciated.
