此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
没有音频?更换耳机插孔即可!
你所需要的
移除下列的 8 颗螺丝:
用于将主板固定至后壳的五颗 2.3 mm #00 半螺纹十字螺丝。
用于固定主板和摄像头的两颗 2.3 mm #00 全螺纹十字螺丝。
在 “Do not remove” 贴纸下方的一颗 2.9 mm #00 十字螺丝。
装回时的说明:
摄像头旁的那颗螺丝(右下角高亮标记的螺丝)有一条用于固定摄像头在位的金属条。
拆下以下 4 颗螺丝:
三颗 1.8 mm Phillips #00 螺丝,用于将耳机插孔和 GPS 天线固定在后壳上。请留意你拆下螺丝的顺序,因为左侧的那颗螺丝头稍大一些。
一颗位于耳机插孔附近塑料环中的 3.8 mm Phillips #00 螺丝。
要重新组装设备,请按相反顺序执行这些说明。
147等其他人完成本指南。
3指南评论
My mute/silent switch went bad. I obtained an assembly that included the metal bracket assembly for the mute switch. Here are some issues I ran into and I hope it helps someone out. This repair takes a while - plan on 2 hours or more! I did all my work in a cookie sheet with white paper on the bottom for contrast. It saved me from losing 1-2 screws. Magnetize your screwdriver. My flex cable needed a lot of careful bending to fit the contours needed to route within the phone. I forgot to fold the actual connector up before inserting the logic board, which meant it was hiding under the board, and I didn't notice until I had fully installed the board. This is easy to do on a new flex assembly because the connector want's to lie flat! On reassembly, I had success putting the mute button on the switch, then installing that combination first. Then the volume up/down, then the headphone jack. I placed small plastic shims on the case side and internal side of the headphone jack - for insulation. Part 1
Part 2: Also, there is a gold contact on the top of the headphone jack. There is a spring contact on the display assembly that contacts this - I had to bend my spring down a bit. If this contact is not good the symptom is you won't really be able to turn the headphone volume down low (it stays pretty loud), and you'll get a LOUD click when moving off minimum volume. Also, if you try the phone before fully assembling it keep in mind the "home" button won't work until the display is fully seated into the case.
Hi, -Yeasterday night i did it! Replacing iPhone 3GS Headphone Jack mission Completed!
advice: use a support to view better the screw.
use a 10x lens to help your view
make a sandwich falt cable as per original before put in place (can help and more easy)
bye Giampiero
