跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Battery Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Battery Installation, Clean the frame: 步骤 1 中的图像 1,2 iPhone 16 Pro Battery Installation, Clean the frame: 步骤 1 中的图像 2,2
    • Remove any remaining adhesive from the battery recess.
    • Wipe the frame surface with a lint-free cloth and a few drops of isopropyl alcohol. Wait for the alcohol to fully evaporate before installing the new battery.
    • Before removing any liners on the adhesive, place the battery in its recess to check that it fits and that its cable reaches its socket on the logic board. Don't connect the battery yet!
  2. iPhone 16 Pro Battery Installation, Install new adhesive: 步骤 2 中的图像 1,3 iPhone 16 Pro Battery Installation, Install new adhesive: 步骤 2 中的图像 2,3 iPhone 16 Pro Battery Installation, Install new adhesive: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Stretch Release Battery Adhesive
    $3.99
    • The next four steps show how to apply custom-cut adhesive to the battery. If your battery comes with adhesive pre-installed, skip the next four steps.
    • If needed, follow this guide to apply generic stretch release adhesive strips instead. Ensure the position of these strips lines up with the adhesive wells in the phone's frame. Use this photo as a reference.
    • Align the new adhesive with your battery to see how it needs to be applied. Set all strips fully on the battery, and align the top edges of the black pull tabs with the bottom edge of the battery.
    • Your adhesive may look slightly different or have different liners.
    • If the battery‑side of your adhesive has two liners, remove the top liner.
    • If the battery‑side of your adhesive has one liner, remove it.
  3. iPhone 16 Pro Battery Installation: 步骤 3 中的图像 1,2 iPhone 16 Pro Battery Installation: 步骤 3 中的图像 2,2
    • Lay the adhesive onto the battery and press each strip firmly into place.
  4. iPhone 16 Pro Battery Installation: 步骤 4 中的图像 1,3 iPhone 16 Pro Battery Installation: 步骤 4 中的图像 2,3 iPhone 16 Pro Battery Installation: 步骤 4 中的图像 3,3
    • If the battery‑side of your adhesive still has a bottom liner on it, remove it now, and press each strip firmly into place.
  5. iPhone 16 Pro Battery Installation: 步骤 5 中的图像 1,1
    • Use your finger to fold each black pull tab around the bottom edge of the battery and press it into place.
  6. iPhone 16 Pro Battery Installation, Remove the adhesive film: 步骤 6 中的图像 1,3 iPhone 16 Pro Battery Installation, Remove the adhesive film: 步骤 6 中的图像 2,3 iPhone 16 Pro Battery Installation, Remove the adhesive film: 步骤 6 中的图像 3,3
    • Remove the iPhone‑side liner off of the battery adhesive.
  7. iPhone 16 Pro Battery Installation, Align the battery: 步骤 7 中的图像 1,3 iPhone 16 Pro Battery Installation, Align the battery: 步骤 7 中的图像 2,3 iPhone 16 Pro Battery Installation, Align the battery: 步骤 7 中的图像 3,3
    • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
    • Lower the battery partially into its recess, making sure the adhesive doesn't touch the frame.
    • Use a spudger or your finger to connect the battery cable's press connector to ensure that the cable reaches.
  8. iPhone 16 Pro Battery Installation, Install the battery: 步骤 8 中的图像 1,3 iPhone 16 Pro Battery Installation, Install the battery: 步骤 8 中的图像 2,3 iPhone 16 Pro Battery Installation, Install the battery: 步骤 8 中的图像 3,3
    • Push the battery towards the top of the iPhone, and lay it in its recess.
    • Use your fingers to press firmly against the battery for ten seconds to bond it to the frame.
    • Use a spudger or your finger to disconnect the battery from the logic board.
终点
Nick Schultz
于03/24/24注册
39,338 声望
创作了226篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,992篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 84
