本指南有最近更改,您可查看未经巡查的最新版本。
简介
按照本指南取下iPad的逻辑板。
你所需要的
在显示屏组件和后壳之间的顶部插入金属撬棒。
抬起撬棒来释放显示屏顶角的卡扣。
在顶角处显示屏和后壳之间插入第二根金属撬棒,防止卡扣自动归位。
使用一个撬棒来在iPad的右边沿工作。
前面板被顶部底部和左侧的金属卡扣与铝制背板相固定。 右侧为塑料卡扣在身处固定。。
一旦卡扣被释放,将前面板的左侧向上提起,然后开始撬动左侧,来释放与后铝制面板之间的卡扣。
Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
在接下来几步中,您将要断开三条将显示屏与逻辑板相连的排线。 线缆是下列几种:
数字化线缆
光感传感器
显示数据线
It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
使用塑料打开工具来翻转挡板来解锁固定在逻辑板插座上的数字化线缆。
将数字化线缆直接从插座中拉出
Adding this comment in its proper place:
After flipping up the metal retainer, pull it sideways.
Do not pull it up vertically.
从主板中翻转金属固定器,断开显示数据线缆与主板的连接。
从插座中拉出线缆。
IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
使用塑料打开工具撬开边缘:
从侧面的电线上将侧按钮从逻辑板上取下。
将扬声器从扬声器导线下方的逻辑板上的插座上拔下。
小心地将ZIF带状电路保持盖翻转在耳机插孔附近的插座上。
将耳机插孔带状电路拉向iPad的左侧,以将其与插座断开连接。
Just skip removing the “side button connector” as you may instead sever the small solder connections to the socket. It’s not a necessary step and is more dangerous than anything.
Max Powers - 回复
I wish I had understood your post a little better, the socket popped off of the logic board for me. Is there any way to reconnect it or did I just waste my money trying to fix my own device? Thanks for any suggestions, listen to Max, good advice, there’s no reason to remove that connection and it just puts you in danger of doing what i did. Good luck to all.
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
27等其他人完成本指南。
由衷感谢以下译者:
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
Isn't the firmware containing the serial number on the logic board? If so you would need to add the serial number back in right?
Can I change the logic board from another iPad to this one?
Hi my gen 5 ipod touch( yep had it forever) screen broke yet that far back replacing that not worth the effort. Want to try and use any hardware it didn't ruin when i sat on it. try to connect to my hp monitor from 2003? Maybe? thanks for reading. cheers
1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
2) If so,will the tape take the display’s oleophobic coating with it when removed?
Mitch Stary - 回复
Hola necesito comprar
Alsone Michel - 回复
Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
iPad LCD Panel
Safety Glasses
Sandra Hiller -
