跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的iPad ClamCase,应参考我们的维修指南
    1. iPad ClamCase, iPad ClamCase: 步骤 1 中的图像 1,2 iPad ClamCase, iPad ClamCase: 步骤 1 中的图像 2,2
      • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
      • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
      • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
      询问修复机器人
      添加评论
    2. iPad ClamCase: 步骤 2 中的图像 1,2 iPad ClamCase: 步骤 2 中的图像 2,2
      • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
      • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
      询问修复机器人
      添加评论
    3. iPad ClamCase: 步骤 3 中的图像 1,2 iPad ClamCase: 步骤 3 中的图像 2,2
      • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
      • Be patient, the thin black covering might be really stuck to the bottom.
      询问修复机器人
      添加评论
    4. iPad ClamCase: 步骤 4 中的图像 1,1
      • Once the thin black covering is removed, you will see 15 screws.
      • Use the T6 Torx screwdriver to remove the screws.
      询问修复机器人
      添加评论
    5. iPad ClamCase: 步骤 5 中的图像 1,1
      • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
      询问修复机器人
      添加评论
    6. iPad ClamCase: 步骤 6 中的图像 1,1
      • You are done.
      询问修复机器人
      添加评论
2指南评论
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - 回复 分享
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 43
总计 8,256
