简介
适用本指南来为iPad Air 2 Wi-Fi 更换逻辑板。 注意:更换逻辑板将会导致您的信息丢失以及Touch ID无法正常工作。
如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害您,请使用胶带来固定已经碎裂的屏幕。
给iPad 的正面整面贴上胶带。
尽量根据下面的指南进行操作。但,一旦玻璃破碎,请停下拆解并使用金属撬刀撬出玻璃,避免更多的碎裂。
按照本指南相反步骤来重新组装设备。
按照本指南相反步骤来重新组装设备。
27等其他人完成本指南。
特别感谢这些译者︰
100%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
7条评论
If the logic board needs to be replaced, does that contain all the memory of the iPad? By installing a new logic board, do you basically start with a clean slate?
yes, effectively like swapping out the desktop but keeping screen, keyboard and outer box. the Memory is build into this
Hello,
Is there a Logic board with LTE for iPad Air 2? Can't find some in your store.
If not, is it possible to replace the logic board from an ipad with cellular with a logic board with only wifi? So after this I would have a iPad without cellular, but at least a working one.
br,
Max
Are 16GB, 64GB, and 128GB logic boards interchangeable or do I need to match what was previously in the ipad? Also, if I leave the existing home button in there I will only lose fingerprint recognition, correct?
Thanks.
