简介
按照本指南中的步骤,在您的iPad Air 2 中更换Home键组件(包括垫圈和电缆)。请注意,Home键与它们各自的逻辑板相匹配,所以在完成Home键更换后,指纹解锁将不再工作。
如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害您,请使用胶带来固定已经碎裂的屏幕。
给iPad 的正面整面贴上胶带。
尽量根据下面的指南进行操作。但,一旦玻璃破碎,请停下拆解并使用金属撬刀撬出玻璃,避免更多的碎裂。
在复原设备时,请依照指南以相反的步骤将其复原。
34等其他人完成本指南。
特别感谢这些译者︰
75%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
11条评论
There is a small black plastic ring between the back of the glass and the home button gasket that no one seems to be mentioning. Do you see it? It does not appear on any of the photos. What's up with that?
Its the washer, better to transfer to new screen if the screen does not come with the washer. Without the washer the home button will work fine, just feel weird. Good luck
As I understand it, the touch ID chip on the home button ribbon cable is paired to the logic board at the factory. Unless you put the same home button assembly back, you will lose the touch ID when a replacement home button assembly is installed. The home button will work but without touch ID
