跳转到主内容
iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement
你所需要的
  1. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Install the iMac service wedge: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 21.5" Cardboard Service Wedge
    购买
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Insert the opening tool: 步骤 2 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Insert the opening tool: 步骤 2 中的图像 2,2
    • Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  3. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Slice through the display adhesive: 步骤 3 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Slice through the display adhesive: 步骤 3 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Slice through the display adhesive: 步骤 3 中的图像 3,3
    • Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
    • Be sure to always push with the cutting wheel forward. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 4 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 4 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 4 中的图像 3,3
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 5 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 6 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Continue along the top of the display.
    • You may want to run the tool back and forth a few times to ensure you completely cut through the adhesive.
  7. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 7 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 7 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 7 中的图像 3,3
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 8 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 8 中的图像 2,2
    • Push the tool down along the right side of the display.
  9. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 9 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 9 中的图像 2,2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 10 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 10 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 11 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 11 中的图像 2,2
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 12 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 12 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 12 中的图像 3,3
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 13 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 13 中的图像 2,2
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 14 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 14 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 14 中的图像 3,3
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 15 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 15 中的图像 2,2
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 16 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 16 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 16 中的图像 3,3
    • Slide the plastic card toward the center.
    • Stop sliding just before the iSight camera to avoid damaging the camera.
  17. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 17 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 17 中的图像 2,2
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 18 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 18 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 18 中的图像 3,3
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Display Assembly Cables: 步骤 19 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Display Assembly Cables: 步骤 19 中的图像 2,2
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
  20. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 20 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 20 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 20 中的图像 3,3
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
  21. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Separate the display: 步骤 21 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Separate the display: 步骤 21 中的图像 2,2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 22 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 22 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 22 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  23. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 23 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 23 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 23 中的图像 3,3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
  24. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Remove the lower support bracket: 步骤 24 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Remove the lower support bracket: 步骤 24 中的图像 2,2
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  25. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 25 中的图像 1,1
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
  26. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Hard Drive Brackets: 步骤 26 中的图像 1,1
    • Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
    • Two 21 mm screws
    • One 9 mm screw
    • One 27 mm screw
  27. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 27 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 27 中的图像 2,2
    • Remove the left and right hard drive brackets from the iMac.
  28. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Power Supply: 步骤 28 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Power Supply: 步骤 28 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Power Supply: 步骤 28 中的图像 3,3
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board.
    • Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
  29. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 29 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 29 中的图像 2,2
    • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  30. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 30 中的图像 1,1
    • Remove the two 7.2 mm T8 Torx screws securing the power supply to the rear enclosure.
  31. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 31 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 31 中的图像 2,2
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Tilt the power supply forward.
  32. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 32 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 32 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 32 中的图像 3,3
    • Pull the power supply slightly up and out from the rear enclosure.
    • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  33. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 33 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 33 中的图像 2,2
    • Slide the power supply to the right to clear the screw posts on the rear enclosure.
  34. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 34 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 34 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 34 中的图像 3,3
    • Rock the power supply forward and remove it from its recess in the rear enclosure.
    • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  35. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 35 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 35 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 35 中的图像 3,3
    • Do not let any of the exposed solder joints come in contact with a metal surface, as that can cause a short.
    • Flip the power supply over to access the DC power cable connection behind the logic board.
    • To disconnect the cable, squeeze the release clip on the back side of the connector, behind the logic board, and pull the connector straight out.
  36. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 36 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 36 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 36 中的图像 3,3
    • You may find it helpful to set the iMac down on its back for the next couple of steps.
    • Use the flat end of a spudger to press the release clip on the side of the AC inlet cable connector inward.
    • While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  37. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 37 中的图像 1,1
    • Remove the power supply from the iMac.
  38. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Fan: 步骤 38 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Fan: 步骤 38 中的图像 2,2
    • Gently pull the fan cable connector straight out of its socket on the logic board.
  39. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 39 中的图像 1,1
    • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
  40. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 40 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 40 中的图像 2,2
    • Remove the fan from the iMac.
  41. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Hard Drive Assembly: 步骤 41 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Hard Drive Assembly: 步骤 41 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Hard Drive Assembly: 步骤 41 中的图像 3,3
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  42. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 42 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 42 中的图像 2,2
    • Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
  43. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 43 中的图像 1,1
    • Remove the hard drive assembly from the iMac.
  44. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Remove the hard drive tray: 步骤 44 中的图像 1,1
    • Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
  45. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 45 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 45 中的图像 2,2
    • Remove the SATA cable from the clips on the back of the hard drive tray.
    • Remove the hard drive tray.
  46. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Disconnect the logic board: 步骤 46 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Disconnect the logic board: 步骤 46 中的图像 2,2
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  47. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 47 中的图像 1,1
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  48. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 48 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 48 中的图像 2,2
    • Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
  49. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 49 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 49 中的图像 2,2
    • Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
  50. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 50 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 50 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 50 中的图像 3,3
    • Flip up the metal retaining bracket on the FaceTime camera cable connector.
    • Pull the iSight camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  51. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 51 中的图像 1,1
    • Remove the two 4.0 mm T5 Torx screws securing the four AirPort/Bluetooth antenna connectors.
  52. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 52 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 52 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 52 中的图像 3,3
    • Rotate the top of the AirPort/Bluetooth connector bracket away from the logic board, then lift the bracket straight up and remove it.
    • During reinstallation, make sure to line up the tabs on the bottom of the bracket with the holes in the EMI shield. These tabs should seat fully inside the holes before the bracket is installed.
  53. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 53 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 53 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 53 中的图像 3,3
    • Use the point of a spudger to pry all four antenna connectors straight up from their sockets and disconnect them from the AirPort/Bluetooth card.
  54. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 54 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 54 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers or your fingers to pull the right speaker cable connector straight down and out of its socket on the logic board.
  55. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 55 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 55 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 55 中的图像 3,3
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right to move it out of the way of the logic board.
  56. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 56 中的图像 1,1
    • Peel off the tape covering the exhaust duct.
  57. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 57 中的图像 1,1
    • Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
    • Two 6.2 mm screws
    • Two 4.7 mm screws
  58. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 58 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 58 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 58 中的图像 3,3
    • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
  59. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Remove the logic board: 步骤 59 中的图像 1,1
    • Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
  60. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 60 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 60 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 60 中的图像 3,3
    • When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left of the board.
    • Tilt the top of the logic board away from the rear enclosure.
    • As you tilt the logic board, pull the right speaker connector to the right and out of the way of the board.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear enclosure's screw posts.
  61. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 61 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 61 中的图像 2,2
    • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
    • Use a USB flash drive and/or ethernet cable to keep the logic board seated correctly while you tighten the screws.
  62. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, SATA Data and Power Cables: 步骤 62 中的图像 1,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, SATA Data and Power Cables: 步骤 62 中的图像 2,3 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, SATA Data and Power Cables: 步骤 62 中的图像 3,3
    • The SATA data connector has a clip that must be pressed to allow removal.
    • While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
  63. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 63 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 63 中的图像 2,2
    • Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
  64. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Heat Sink: 步骤 64 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement, Heat Sink: 步骤 64 中的图像 2,2
    • Peel off the four black tamper-evident stickers covering the heat sink mounting screws.
    • Remove the four T10 screws that secure the heat sink from the backside of the logic board.
    • During reassembly, tighten these screws one full turn at a time, alternating in a cross pattern. This will gradually increase the clamping pressure evenly across the surface of the CPU. Continue gradually tightening the screws until they're snug and the entire spring plate lays flat against the logic board.
  65. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 65 中的图像 1,2 iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 65 中的图像 2,2
    • Lift the heat sink retaining spring and its bracket off the logic board.
  66. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 66 中的图像 1,1
    • Fully loosen the three captive T8 screws securing the heat sink over the GPU.
    • Remove the two 5.4 mm T8 screws securing the heat pipe to the logic board.
  67. iMac Intel 21.5" Retina 4K Display 2019 Heat Sink Replacement: 步骤 67 中的图像 1,1
    • Note that the CPU will most likely remain stuck to the underside of the heat sink as it's lifted out. Take care not to damage it.
    • Lift and remove the heat sink assembly from the logic board.
    • When reassembling your iMac, remove the CPU from the heat sink and reinstall it separately from the heat sink. This will make sure it's installed correctly and prevent damage.
    • Follow our thermal paste application guide to reapply the thermal paste to the graphics processor (GPU). You should also replace the heavy thermal compound or apply thermal pads to the VRAM chips.
结论
另外一个人完成了本指南。
Adam O'Camb
于04/11/15注册
198,503 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 110
总计 4,019
