跳转到主内容
iMac Intel 21.5" EMC 2544 胶条更换
你所需要的
  1. iMac Intel 21.5" EMC 2544 胶条更换, 放置iMac支架: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 21.5" Cardboard Service Wedge
    • 一旦铰链可以自由移动,iMac 将失去平衡,难以操作。在支架上放置一个 iMac 支架 以稳定 iMac。
    • 如果使用 iFixit iMac支架,请按照 本组装教程 进行组装。
    • 如果没有 iMac 支架,请小心操作,因为如果 iMac 意外移动,显示屏很容易脱落和损坏。
    I made one out of a square cardboard box, and working well so far
    Will Moindrot - 回复
  2. iMac Intel 21.5" EMC 2544 胶条更换, 移除旧的胶条: 步骤 2 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换, 移除旧的胶条: 步骤 2 中的图像 2,2
    • 安装新胶条之前,请清除后机箱周边的所有旧胶条。
    • 如果要重复使用现有的显示屏,还必须清除显示屏背面的旧粘胶。
    • 用镊子或手指剥离旧的胶条。从底部开始,向设备顶部向上剥离。
    • 清除所有旧胶条后,用高浓度异丙醇(90% 或更高)和无绒布仔细擦去胶条残留物。顺着一个方向擦拭,不要来回擦拭。
    • 请不要跳过这一步,否则新胶条可能无法正常粘合,显示屏可能会从 iMac 中脱落。
    The aluminum frame have a plastic zone. Could the isopropyl alcohol damage the plastic surface?
    Fer Triva - 回复
    Hello! Isopropyl alcohol should not damage the plastic surface.
    Arthur Shi -
    It’s not clear if you’re supposed to remove the black strips under the adhesives from the screen. Sometimes they come off when removing the main adhesives, but they seem to be two separate layers.
    online - 回复
    Only the adhesive should be removed—the black strips underneath them should stay in place.
    Arthur Shi -
    “Only the adhesive should be removed—the black strips underneath them should stay in place.”
    By fault I’ve removed the black strips, now there is a gap between the glass and the aluminum frame in the bottom.
    the display is perfectly pasted, it’s only a matter of appearance…
    If I open the computer again, what kind of adhesive tape (caption tape?) could I use to eliminate the gap between the glass and the frame?
    Or it’s better to let it go…
    Thanks for your support
    Massimiliano Nannetti - 回复
    Hi Massimiliano ,
    You should be fine. The bottom edge doesn’t have black strips. It should be bare metal. However, there shouldn’t be any gaps between the glass and the frame. Make sure that the adhesive is fully adhered on the bottom edge.
    Arthur Shi -
    Hi Arthur,
    my English is not perfect…
    I would mean that I removed all the black strips under the adhesives on the screen; so I believe that the glass has become too thin compared to the bottom aluminium frame.
    I thought to open the Mac again and put some black strips to increase the thickness of the glass screen but I don’t know what kind of tape I should use (Kapton or other?).
    And then I will put a new set of ifixit adhesives strips.
    Maybe it’s a waste of time… it’ s only an aesthetic matter
    Thanks again
    Thanks for the clarification. Since there is always a chance to crack the screen glass when cutting the adhesive, I’d suggest not to open up the iMac again. However, if you do open it, I suggest using Tesa tape.
    Arthur Shi -
    Thanks Arthur,
    I will follow your suggestion… I will not open again my computer…
    Now it works very well and fast.
    So, the bit about the adhesive strips really needs to be clarified. Nowhere in the instructions is there talk about multiple layers of adhesive, one that should be removed and one that should remain. And looking at the pictures further on, clearly the wider sections where the adhesive go are completely clean of any black strips. However, on the screen side, I’ve noted that indeed there are two layers, at least on the top. And removing both layers leads to the adhesive *not* really taking hold and the screens falling out. Really wish this had been clearer. I’ve helped dozens of people upgrade their iMac but after the first time that I had to replace a screen due to it falling and breaking, I’ve been using clear strong adhesive tape externally on the corners to ensure that the screen stays in place. Ugly, but better than the risk.
    David - 回复
    Are you sure there are 2 layers of tape? My replacement tape comes with the sections that sticks over the 2x antenna sections on the right side of the screen (looking at the screen). The old tape has antenna section left over because only the thinner edge part was cut so that section separated.
    Furthermore, the replacement tape on the antenna section is only sticky on 1 side (facing the chassis) and no sticky surface to the screen (other than the thin 5-6mm width edge like the rest of the none antenna section.
    As for falling off, I'm guessing there are 1. cheap tapes that looks the part but don't stick as well 2. surfaces not cleaned and primed 3) 2 top corner breathing channel (hot air rise and go out there) got sealed off as Step 6 below + pulling and stretching the tape sealed off that channel. Happened to me the first time, had to cut back to expose the air channel. On subsequent efforts, didn't pull to stretch the tape. Went gradually a couple of inches at a time so the tape don't stretch.
    Howard -
    I’m putting in an SSD, don’t have any strips. Would super glue work?
    natfrey - 回复
    no! don't do that. if for any reason in the future you need to open it up again, you will only destroy your screen. you can get strips really cheap on Amazon.
    David -
    I too started removing the second layer of adhesive strips before reading these comments. PLEASE update the article to reflect that the other black strips should stay!
    Mark Sandell - 回复
    A few key notes
    2 top corners have air gaps to let the hot air out. When applying the new tapes, its easy to stretch the tape and seal this hole using the method outlined below. Best to go slowly small section at a time to avoid stretching the tape. 2 people is helpful.
    Before peeling the tape facing the LCD, its good to mount the LCD with masking tape (avoid covering mic holes) to test everything. I like to use Photo Booth and record a video to ensure camera and mics are all working properly.
    2 people also helpful on the final reseal. I like to stand the iMac up vertically so can power on and do final check after LCD connection before reseal. The screen is pivots on the bottom edge and iMac chassis is wobbly on its stand so 2 people is helpful. For final check, I like to make sure screen powers on and display shows before final reseal.
    Howard - 回复
  3. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 3 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 3 中的图像 2,2
    • 胶条上应预留麦克风缺口,标有 4R。
    • 如果你的 4R 胶条不包含凹槽,请查看本指南
    As far as I can tell, this model still had the mic at the top near the webcam, not at the bottom, so this notch is not needed for this model (2014 21.5” iMac A1418)
    Neddy - 回复
  4. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 4 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 4 中的图像 2,2
    • 事先铺好胶条,这样就不会不小心把胶条装错位置:
    • 胶条1在左上方摆放
    • 胶条2在右上方摆放
    • 胶条3在右侧垂直摆放
    • 胶条 4R 在右下方摆放,暗面朝上
    • 胶条 4L 在左下方摆放,暗面朝上
    • 胶条5在左侧垂直摆放
  5. iMac Intel 21.5" EMC 2544 胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换, 撕掉第一条胶带上的背胶: 步骤 5 中的图像 3,3
    • 从第 03 条开始,它位于后机箱的右侧垂直面上。
    • 在撕下任何背胶之前,将胶带沿着 iMac 的框架对比,以了解它的位置。
    • 抓住蓝色标签,从条带背面剥下一小块背胶,露出一段粘合剂,将其固定在外壳上。
  6. iMac Intel 21.5" EMC 2544 胶条更换, 粘贴第一条胶条: 步骤 6 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换, 粘贴第一条胶条: 步骤 6 中的图像 2,2
    • 将撬棒的尖端插入刚刚移除一层背胶的胶条末端的孔中。 从仍有一层白色背胶的一侧插入撬棒。
  7. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 7 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 7 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 7 中的图像 3,3
    • 在撬棒仍然从胶带上的孔中戳出的情况下,将撬棒尖端推入 iMac 框架上相应的孔中。
    • 使用孔和撬棒固定胶条的位置,将胶条与右边缘对齐,轻轻向上拉动撬棒以确保胶条拉紧,然后将其粘贴到框架上。
  8. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 8 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 8 中的图像 2,2
    • 对齐胶条的下半部分后,将较长的背衬从胶条后面剥离。
    • 如果下半部分未正确对齐,你可以小心地将其剥离并重新粘贴,然后再剥离下背衬条。 请务必使用撬棒尖端固定顶部。
  9. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 9 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 9 中的图像 2,2
    • 将胶条的上半部分与后外壳的右边缘对齐,然后将其粘贴下来。
  10. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 10 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 10 中的图像 2,2
    • 用手指抚平胶条。确保它与框架的右侧整齐对齐,并且平整。
    • 先不要剥离前面的背胶。
  11. iMac Intel 21.5" EMC 2544 胶条更换, 贴上剩余的胶条: 步骤 11 中的图像 1,1
    • 按逆时针方向,在 iMac 的四周,以同样的方式再添加三条胶条:
    • 右上方的胶条2
    • 左上方的胶条1
    • 左侧垂直的胶条5
  12. iMac Intel 21.5" EMC 2544 胶条更换, 黏上底部胶条: 步骤 12 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换, 黏上底部胶条: 步骤 12 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换, 黏上底部胶条: 步骤 12 中的图像 3,3
    • 接下来的几个步骤将展示如何安装右下角的胶带(胶带 4R),其中包括一个必须与麦克风对齐的凹口。
    • 在尝试操作之前,请通读此步骤和接下来的四个步骤。
    • 抓住条带 4R 上的红色拉片,拉动使约 2 英寸(5 厘米)的白色背胶与胶条分离。
    These steps instruct you to install the lower strips to the iMac frame first, as that is what Apple instructs their techs to do. If you have an iMac without a microphone hole, you can choose to install the lower strips onto the display first. Peel the blue tab instead of the red to expose the adhesive. Carefully place the adhesive along the bottom edge of the display. The L-bend on the adhesive should match the display contours.
    Arthur Shi - 回复
    i have no microphone hole - which is good . . . because the 4R and 4L stips must be labelled incorrectly as the L’s are on the wrong side. Also the strips don’t completely cover the bottom. And there are no holes in these strips making placement less secure. Someone certainly goofed. (Reckon I’ll use snipped off L’s to cover the open space.
    George Guess - 回复
    Ah, the L strips don’t overlap - so they’re long enuf, but they are still reversed.
    George Guess - 回复
    Die Löcher in den Klebestreifen passen nicht (mehr) zu den Löchern im Rahmen. Ich habe mich an den breiten Stellen orientiert und die Klebestreifen daran ausgerichtet. Das ging besser.
    The holes in the adhesive strips no longer match the holes in the frame. I oriented myself towards the wide areas and aligned the adhesive strips with them. That worked better.
    Stefan - 回复
  13. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 13 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 13 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 13 中的图像 3,3
    • 将剥下的白背胶底折成直角,用手指捏住折痕。
    • 这样就会露出 2 英寸的粘合剂,同时将红色标签折叠出来。
  14. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 14 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 14 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 14 中的图像 3,3
    • 麦克风孔是 中心孔,两侧有两个较大的孔。
    • 将麦克风槽口对准麦克风孔,将胶条对准底部边缘。
    • 如果你的 iMac 没有麦克风孔,请对齐胶条的右端,使 L 形弯头位于右侧垂直粘合剂旁边. L 形弯曲不应与右侧垂直胶条重叠。
    • 胶条很容易撕裂。注意不要用力过猛拉扯胶条。
    • 对齐胶条后,小心地将左侧露出的边缘固定在 iMac 上,以确保对齐。
    The strips that I received from OWC do not have a notch cut out for the microphone. The instructions advise you, for 2017 and later 21.5” iMacs, to cut about 2 inches off from the left side of the strip so you do not cover the microphone hole.
    Peter Hillman - 回复
    As far as the remaining 2 inches I cut off, I snipped off a little more on the right side to leave a small gap for the microphone and placed that small remaining part in the center where it should have been if there was no microphone, just to complete the adhesive.
    Peter Hillman - 回复
    I have done quite a few of these now. It is easier to apply the bottom strips to the Display, rather than the housing. With the Red tabs folded at 90 degrees to the adhesive. You can then remove these tabs with the display kind in place, secured by painters tape on the out side before closing it up.
    Charlie Nancarrow - 回复
    Don't make the mistake i just did - if you want to cut a notch, cut the BOTTOM 2/3rds section of the strip, not the top! :P
    Also, here's a some pics of the mic location in the 2017 retina version from iFIXit: Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips.
    Philip Sedlmair - 回复
  15. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 15 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 15 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 15 中的图像 3,3
    • 剥去胶条后面的白色背胶,露出剩余的粘合剂。
  16. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 16 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 16 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 16 中的图像 3,3
    • 用手指沿着胶条的长度从左到右划,确保胶条平直无皱,边划边向下按,将胶条粘在 iMac 上。
  17. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 17 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 17 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 17 中的图像 3,3
  18. iMac Intel 21.5" EMC 2544 胶条更换, 安装屏幕: 步骤 18 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换, 安装屏幕: 步骤 18 中的图像 2,2
    • 将显示屏轻轻放在 iMac 上,并仔细对齐。
    In my experience, it is easier to lay the Mac flat on its back, especially if you do not have a wedge, because the display will tilt up and down and you do not want that happening. With the Mac on its back, I removed all the front adhesive strips and then angled the display (not a big angle) against the chin making sure it was even on both sides. Then reconnect the video cables and gently bring the display down into the proper position. Step 23 below seems too much of a hassle to try and get the bottom adhesive strips out while the display is resting on them, and taping the bottom of the display in Step 19 also seems to be a hassle.
    Peter Hillman - 回复
  19. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 19 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 19 中的图像 2,2
    • 使用宽胶带将显示屏底部边缘暂时固定在 iMac 机箱上。
    • 胶带可保持显示屏的对齐,并允许你安全地打开显示屏的顶部边缘,以触及到显示屏排线。
    • 不要将胶带缠绕在 iMac 背面,否则在连排线时可能会弄碎屏幕。
    Noooo!! I followed this step and promptly cracked my screen!!!! You need to be extremely careful NOT to wrap the tape around the back of the computer. These images make it look like it's wrapped around, but if you do that, you won't be able to lift the screen at all to attach the display cables. Why?!!!!!
    Mark Sandell - 回复
    Oh no! I'm so sorry to hear this! Thank you for sharing your experience—I'm going to add a warning into the step.
    Arthur Shi -
  20. iMac Intel 21.5" EMC 2544 胶条更换, 测试屏幕: 步骤 20 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换, 测试屏幕: 步骤 20 中的图像 2,2
    • 此时,最好测试一下你的修复工作,以确保你的 iMac 能正常工作,然后再将其重新封好。请按照以下三个步骤暂时重新连接显示屏排线,并在从胶条上撕下保护膜之前启动 iMac。
    • 如果你已确认 iMac 工作正常,并准备将其密封,请跳过下一步。
    • 将显示屏电源线插入主板上的插座。
    I am powering the unit back up to test all is working. Screen is black but fan is running loud. I’ve decoupled the power and confirmed both the display cables are connected. Note - I replaced both the HDD with a SSD as well as upgraded the RAM from 8GB to 16GB.
    Neil Harfert - 回复
  21. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 21 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 21 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 21 中的图像 3,3
    • 用镊子或另一只手将显示数据排线插口轻轻插入主板上的插座。
    • 确保将其直接按入插座,并完全插入。
    • 将显示屏数据线上的金属保护罩向下朝向主板固定。
    While the previous step refers to “cables,” plural, this step suggests that only the display cable needs to be reinstalled in order to test working order. In my experience (iMac 21-1/2" Retina 4K Display, late 2015), I found that I had to also reconnect the camera/microphone cable in order for the screen to work. [6/7/21]
    Gary Heurich - 回复
  22. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 22 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 22 中的图像 2,2
    • 将显示屏装回 iMac 的后机箱。
    • 此时,请插入 iMac 电源,并测试你的修复工作,然后再继续实际密封电脑。请务必检查已移除或断开连接的硬件是否完全正常。
    • 完成后,请关闭 iMac 并拔下电源线,然后再继续。
    At this point I tested everything to make sure it worked, including the microphone. It was a bit muffled so I poked it with a pin to try and clear it. This was incredibly stupid because (a) the muffling was due to the backing which I was about to remove from the strip (b) poking with a pin broke the microphone.
    I’m not going to buy a new microphone (£72 apparently) and a new set of strips, so I’ll get an external USB microphone instead.
    But to anyone else, if the microphone sound is muffled, don’t worry!
    rjbusenet - 回复
  23. iMac Intel 21.5" EMC 2544 胶条更换, 密封iMac: 步骤 23 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换, 密封iMac: 步骤 23 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换, 密封iMac: 步骤 23 中的图像 3,3
    • 继续之前,请确认 iMac 已关闭并拔下电源插头。
    • 确认 iMac 功能正常后,断开显示屏排线,小心地将显示屏向前倾斜。
    • 用镊子从上方伸入,然后从显示屏的底部边缘向上拉蓝色拉片,从两个底部条带上取下薄膜。
  24. iMac Intel 21.5" EMC 2544 胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换, 重新连接显示屏排线: 步骤 24 中的图像 3,3
    • 最后一次重新连接显示器电源线和数据线。
    • 切记固定显示屏数据线上的金属保护壳。
  25. iMac Intel 21.5" EMC 2544 胶条更换, 清除剩余的背胶: 步骤 25 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换, 清除剩余的背胶: 步骤 25 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换, 清除剩余的背胶: 步骤 25 中的图像 3,3
    • 检查摄像头正前方的玻璃是否有灰尘和其他污染物。如有必要,在密封显示屏前用超细纤维布擦拭。
    • 在以下步骤中取下保护膜时,用一只手稳住显示屏,或将显示屏轻轻靠在 iMac 的外壳上。
  26. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 26 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 26 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 26 中的图像 3,3
    • 垂直向上拉动胶带 01 的拉片,将其撕下。
  27. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 27 中的图像 1,2 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 27 中的图像 2,2
    • 从胶带 1 上撕下背胶的另一面。
  28. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 28 中的图像 1,1
    • 重复前面的步骤,撕掉所有剩余胶条上的背胶。
  29. iMac Intel 21.5" EMC 2544 胶条更换: 步骤 29 中的图像 1,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 29 中的图像 2,3 iMac Intel 21.5" EMC 2544 胶条更换: 步骤 29 中的图像 3,3
    • 为确保粘合牢固,请小心地将 iMac 背面平放(屏幕朝上),然后小心而用力地按压显示屏的所有四个边缘。
    • 撕下将显示屏固定到后壳的胶带。
    • 24 小时后检查显示屏,确保它在 iMac 上没有松动。
    Yo lo pongo sobre una manta con la pantalla apoyada sobre la manta.Pongo trapos o papel de cocina doblado alrededor de la pantalla y lo sujeto con pinzas de tender ropa.Lo dejo así 24 horas y queda perfecto. Saludos y gracias por el tutorial.
    JAIME GARCIA MARTINEZ - 回复
终点
314等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Sam Goldheart
于10/18/12注册
471,438 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,410篇指南
33条评论
Good Lord, why does Apple have to make it so difficult to upgrade or repair? There comes a point where design aesthetic just isn't worth it. Magnets, like I believe older iMacs use to attach the front glass, would have made it much easier. I'll take the extra bulk any day.
amiller77 - 回复
Have you actually done the replacement? It's actually pretty easy. Apple did everything they could to make it as painless as possible: the old adhesive separates without *any* residue, it doesn't rip apart, it doesn't make a mess. Things align like magic.
True, it could be easier. Like with the old color iMac SD. But since I don't take my iMac apart every day, doing this once or maybe twice in my computer's lifetime is a small price to pay for a *really* slim and good looking device.
Daniel Mores -
I had some issues with steps 21, 22 and 23 ... the tabs would rip off. After the third one I used the plastic card to gently create some space for the strip to escape.
Daniel Mores -
Hello! Tell me, what adhesive tapes are used! Length, width, thickness? On what basis are these tapes?
Oleg - 回复
Thank you for this fantastic guide, and all of the iFixit guides! Just finished this replacement using the iFixit Adhesive Strips/iMac Opener tool combo--everything worked very well, except that the iMac Opener tool did not particularly like the broken glass area of the display, which bent the plastic of the "pizza cutter" wheel a little.
One bit of helpful advice is to use extreme care when placing the replacement display back into the iMac. Make sure that you do not put the display back in at too great of an angle, or there will be a very noticeable gap at the bottom, between the display glass and the iMac frame. Adhesive strips are not forgiving, and rarely give multiple chances!
IT Helper - 回复
We've revised the guide procedure and it makes positioning the screen very easy. You can drop it into place and fine-tune the position to your heart's content. :)
Jeff Suovanen -
Place some sticky tape along the lower edge of the iMac either side of Apple logo. Position screen carefully onto the lower ledge and then use the tape to hold. Tape then acts as a hinge allowing you to raise or lower screen while in the right position. I did this and also used some tape at the top so I could reconnect screen and test HDD install. Then you can hinge screen down to remove the adhesive tape backing strips in order to close up the screen for good!!
finepics - 回复
Thanks for the tip! We've added it to the guide.
Jeff Suovanen -
Somewhere between steps 2 and 3 you might want to add, that you also need to remove the old adhesive from the rear of the screen assembly
petercph - 回复
Good call! Done and done. Thanks!
Jeff Suovanen -
Just successfully upgraded one of these to an SSD using the instructions, tools and adhesive strips from iFixit. The instructions are excellent, and the iMac opener tool does a good job of cutting the adhesive to get it open.The adhesive strips in the kit are excellent - don’t even think about trying to make your own - just buy these and make your life MUCH easier. The final part of using masking tape to position the display before final sealing is very important, and works brilliantly.
Gary Pillans - 回复
I found that for steps 10 & 11, it is better to attach 4R and 4L to the glass directly by removing the blue side of the adhesive strips and placing where they fit correctly onto the glass. Then remove the red tabs just before placing the glass onto the Mac. The right-angle ends of the tape align with the corners on the glass back.
Anthony Saxton - 回复
Of course monitor won't turn on after putting it back in. Any hint?
Joao Paulo Oliveira da Costa - 回复
Joao, I had the same problem just last week. In my case, it seems I hadn’t fully inserted the video cable. I opened it up again, reset the cables, and yes, the video still works. So, open it up, order some new adhesive strips, and be *extra* careful the second time you do it.
David -
This was the toughest part of the HD>>SSD upgrade.Removing all the gunk, and aligning the new strips took more than an hour. The rest half that! But all good now, Thanks Sam.
Stephen Babbage - 回复
Did it this morning, to replace the hhd with an ssd. Went smooth, about one hour all the job. Be patient and it works very well. Now my late 2015 Mac flies, thanks Sam!
Rob - 回复
Thank you for this easy to use guide. Only read, look the pictures and do exactly what to do and the iMac looks like before
Armin Janssen - 回复
Tolle Anleitung, vielen Dank. Ich bin sehr frog, dass es eure Seite gibt. Die Klebestreifen habe ich bei euch gekauft und sie sind sehr gut.
Stefan Fischbach - 回复
This guide is accurate and works just fine. I also have had problems with the tabs pulling off the backing making it difficult to continue. I had problems with 4L & 4R on a previous install and today with the short end of 2. I find that after 4L & 4R removal and mating the bottom, pulling all the strips off keeping the screen spaced 2” or so at the top with one hand, removing all the strips, and then setting the entire screen works best for me.
Jim Rietz - 回复
Hi
Your description does not meet reality.
FIRST
There is another thing to my kit : Number 5 was too long. About 5 mm !!! Did I get the right one ?
Then let’s start with step TWO.
When lifting up the tape from the back of the screen, on the upper side the result was not like on the sides. The tape that came off from the top was almost 10mm wide !! After cleaning I realized that there is a second black tape on the back of the monitor. On the top it is gone now, on the sides it’s still there. What do I do ?
Step THREE
My kit had transparent tape on those tips. Had I everything the wrong way round ?
Let’s go to step ELEVEN
It’s about the second photo with the final image after putting the tapes in place. Why are they all black now ? Whatever is the reason for that, one feels pretty uncertain of the whole procedure. Are both the 4-tapes really the other way round ? On my kit, the red handle would take of the thick paperlike side… ???
So. What do I do with those tapies on the back of the screen. I take them off, right ?
Hunger Lunger - 回复
You want to remove the foam adhesive, as shown in the photos, and nothing else. The wide black mylar layer you’re describing is part of the display itself and should not be removed. If it peels up by accident, carefully smooth it out and stick it back down. Yes, the 4R and 4L strips should be placed exactly as shown in the guide.
Jeff Suovanen -
The same thing happened to me except I throw away the large tape (10mm wide) from the LCD before I realized I should have kept it in place.
Nevertheless, I completed the installation and everything works great except :
1) the LCD is slightly recessed in the enclosure (no big deal)
2) there is a section on the upper left of the screen where there is a gap between the enclosure and the LCD because the adhesive did not stick well there
May the removal of the large LCD tape (10mm wide) be causing the adhesive problem on the upper left of the screen ?
If I want to redo the job to get rid of the two problems I mentioned, what would you suggest me to do ?
Patrick Deschênes -
AVOID SHOCK… just wanted to add - Even with the power cable removed during the process there is still a very strong chance of getting a belt off of the power board… These boards can hold charge for a long time. Do NOT touch the board with tweezers or your fingers when removing the 4L & 4R strips.
howard - 回复
Brilliant guide btw.
However came across a major issue which I think you should update the guide with a note warning other people.
In newer IMacs apple has repositioned the microphone to the bottom bar where the 4r &4l strips are placed. The instructions in your guides don’t mention this and the adhesive strips will cover the microphone hole resulting in a muffled microphone input. Just be careful guys.
Jamie Comerford - 回复
Great guide, kudos! Upgraded an old iMac 21.5 late-2012 (EMC 2544).
The stripes (bought with the “pizza-cutter” tool) were of the right length and shape.
One little remark on “Step 4” - “Insert the tip of a spudger into the hole …” : the hole is obstructed by clear film on both sides of the tape; the spudger can’t help with the alignment as suggested, although the film is clear and you can locate the reference hole/notch by looking-thru the clear film. Same holds true for strips 2, 1 and 5.
I found strips 4L and 4R (steps 10, 11) to be the challenging ones: start from the sides of the central screw, lay down in place the (partially peeled) portion of the tape and, while progressing, gently peel-off the portion of the tape to stick next. The lower edge of the tape almost sits on the ledge of the aluminum front part of the chassis. Never pull the tape as the peeled part is easy to stretch along its length.
On step 13, securing the bottom side of the screen with masking tape was a brilliant idea.
Many thanks!!
Mauro Bardelle - 回复
I have a difficult time removing the display. The adhesive seems to be sticking to much and I am afraid of damaging the display. I have damaged 3 tools and cannot get it to move a bit. Any thoughts?
Hernan Pinzon - 回复
Hello, did it thank you.
For the most part the guide was pretty accurate.
I don’t understand why I couldn’t see it translated (in french) although I know the translation exists
pichel - 回复
Hello! I’m glad you had a successful repair. We updated this guide recently and the updated guide has not been translated yet—it will soon!
Arthur Shi -
Dear Sam and iFixit contributors,
So many thanks for you for this tutorial !
Everything worked fine for me. I replaced my hard disk and mounted back the screen. It took me three hours but I have been patient and I spent some time contemplating the computer’s inside. The ifixit replacement kit was OK.
Cheers !
MILLARES - 回复
An excellent guide. I was nervous before attempting this, but the steps were extremely clear and I completed this without any issue. ?
Brian Bimschleger - 回复
Great guide! I used the apple replacement part kit that comes with both the 04 and 4L & 4R stripes . I will highly suggest to use the 04 on those iMac with microphone on the top and not the center of the bottom adhesive stripe just like mine 21.5" late 2013.
If you use the 4L and 4R you are going to have both ends of the stripe hanging in the air.
guZzy92fs - 回复
I removed the screen in order to upgrade the HDD to an SSD. I found the old adhesive was very difficult to remove from the back of the display panel even with liberal lashings of 100% isopropyl alcohol. Some of the black (paint or tape, or whatever it is) coating on the back of the sides of the screen parted company with the glass thanks to the extended rubbing. Next time I might let it soak for a while and hopefully that will be more successful.
IT Helper's point (May 11 2015) is a good one and I wish I had read that before refitting the screen. If I had done so the result would've been neater.
The opener tool worked a treat.
John McKee - 回复
Done!! Thank you all. Fantastic Guide.
I have learnt something really important when using your guides, spend sometime reading other users comments. It will save you time & money.
Mine --> iMac Retina 4K 21.5-inch 2017
Display removed and set again - 0 problems.
Well done team!!
Pedro Antonio Ribas López - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 93
过去 30 天: 376
总计 94,205
