跳转到主内容
加入维修社区 - 创建账户
iMac G5 20" Model A1076 RAM Replacement
你所需要的
    1. iMac G5 20" Model A1076 RAM Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      添加评论
    2. iMac G5 20" Model A1076 RAM Replacement: 步骤 2 中的图像 1,2 iMac G5 20" Model A1076 RAM Replacement: 步骤 2 中的图像 2,2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 RAM Replacement, RAM: 步骤 3 中的图像 1,2 iMac G5 20" Model A1076 RAM Replacement, RAM: 步骤 3 中的图像 2,2
      • Rotate each of the two RAM retaining arms away from the RAM chip.
      • The chip will partially pop out at the same time as the arms are pulled out to either side.
      • Pull the RAM chip straight away from its socket.
      • Repeat this process for the other RAM chip.
      • Be sure the RAM arms are rotated fully outward before installing new RAM chips.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
31等其他人完成本指南。
2指南评论
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
max sanchez - 回复 分享
Easy as pie, instructions were right to the point, thank you.
Hemi Andersen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 52
总计 24,303
