简介
Like brain surgery? Use this guide to replace your logic board.
你所需要的
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
在这个步骤中使用的工具:Heavy-Duty Spudger$4.99
While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
Twist the heavy duty spudger to slightly separate the connector from its socket.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
62等其他人完成本指南。
