当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Peel the backing off of the adhesive back of the small temperature sensor board.
Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
这个步骤还没有翻译 帮忙翻译一下
Find a connector on the motherboard labeled HD TMP or HDD TEMP.
If the previous temperature cable is still connected to the board here, disconnect and remove it. You will no longer need it.
Connect the temperature sensor's two-wire red-black cable to the motherboard plug labeled HD TMP or HDD TEMP.
Route the excess wire so it does not interfere with any other components.
