跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
iMac 因特尔 21.5" EMC 2389 硬盘更换
你所需要的
  1. iMac 因特尔 21.5" EMC 2389 硬盘更换, 玻璃面板: 步骤 1 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换, 玻璃面板: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • 在开始之前,将您的iMac如图所示放倒在柔软的表面上。
    • 在玻璃面板顶部的两个角上放置吸盘。
    • 要使用我们的吸盘时,首先将吸盘的活动手柄扳动到与玻璃面板平行位置。 在吸盘轻轻地吸在玻璃面板上时,扳动活动手柄使其与另外一个手柄平行。
    • 如果您的吸盘无法吸住,尝试使用温和溶剂清洁玻璃面板和吸盘。
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - 回复
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - 回复
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - 回复
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - 回复
    Nails worked for me too
    Rob Dale - 回复
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - 回复
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - 回复
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - 回复
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - 回复
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - 回复
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - 回复
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - 回复
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - 回复
  2. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 2 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 2 中的图像 2,2
    • 轻轻地竖直提起玻璃面板到足够高的高度来接触玻璃面板顶部下的卡扣。
    • 将玻璃面板拉离iMac的下部,并将面板放在一边。
    • 在重新组装时,请确保已经清理了玻璃面板内部,和LCD表面。当打开电脑时,没人希望看到屏幕里面满是 灰尘和指纹,这样你会抓狂的。
    What's the best product to clean the face of the LCD?
    Steve Speirs - 回复
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - 回复
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - 回复
  3. iMac 因特尔 21.5" EMC 2389 硬盘更换, 显示屏: 步骤 3 中的图像 1,3 iMac 因特尔 21.5" EMC 2389 硬盘更换, 显示屏: 步骤 3 中的图像 2,3 iMac 因特尔 21.5" EMC 2389 硬盘更换, 显示屏: 步骤 3 中的图像 3,3
    • 取下8颗将显示屏与外壳固定的8mm T8梅花螺丝。
    • 最后两张图片为显示屏每侧的细节图片。
    Replacing the screws , especially the two uppermost ones , is awkward due to the magnets attracting the screws off the Torx driver
    Anoop Sahal - 回复
    I’ve done an HDD replacement on an A1174 (and I’m about to do this model), which is nightmarish, but by far the best solution I found was to use a bit of Blu Tack or the equivalent on the driver.
    Boris - 回复
    I’ve just replaced the screws by making a little tube from paper and wrapping it round each screw to keep it contained. A cut-down straw would be perfect for job.
    Guy Whittaker - 回复
    I second this but use a tube of cardboard instead, then its quite easy.
    jeank75 -
  4. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 4 中的图像 1,1
    • 稍微将显示屏从外壳中提出。
    • 切勿提出太多。 还有许多线缆将显示屏与逻辑板相连。
    After sliding the display slightly towards the top edge, enough for the bottom edge to clear the retainers, an alternative is to raise the bottom edge out. Then unplug the LED backlight power cable (this step + 2), unplug the LCD thermal sensor cable (this step + 4), unplug the display data cable (this step + 3), and the display may be rotated over the top edge while leaving the vertical sync cable attached (this step + 1).
    Jerry - 回复
  5. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 5 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 5 中的图像 2,2
    • 将垂直同步电缆连接器从iMac左上角附近的LED驱动板上的插座中拔出。
    Do not try to pull the plug off the circuit board as it's soldered. Pull the cable sideways out of the socket.
    Alex Campbell - 回复
    Skipped step 5-10. I used two 5-6" chopsticks to prop up the display, this gave me more than enough room to complete the rest of the steps. I only had to disconnect the 3 cables are directly connected to the hard drive. Replacing the Seagate hard drive with another Seagate hard drive eliminated any cable issues. Now I have 2TB SSDH
    jaime martinez - 回复
    I was also able to skip steps 5 thru 10, which meant no messing with any cables except for the two for the HD (steps 13+14). Used a credit card to start the removal of glass panel (step 2) - much easier than I imagined. After removing display screws (step 3) I simply had a friend hold up the display's bottom edge as far as the cables would allow (careful not to stress at connection to logic board) and this provided enough room to remove the HD bracket screws (step 11), detach the HD cables, and remove the HD. Was replacing a failed 1TB Seagate with a 3TB Seagate so no problems with compatibility when reattaching the HD cables and everything worked fine when I restored the OS and data to the new HD. No fan issues. I did take great care to not get fingerprints on the inside of the glass panel and to blow off any dust specks before reinstalling it. It was a bit tricky to get the new HD back in without letting the magnets get a hold of it, so thanks for the warning posted here about that!
    Chuckles McBunny - 回复
    On my mid 2010 Imac I found it was not necessary to disconnect any cables (except of course those attached to the drive). Simply angle the monitor away from the case to a safe distance without stressing any cables and secure with tape. With a stubby screw driver it was easy to access and remove the drive.
    Michael Husselbee - 回复
    Skipped steps 6-10; did step 5 so could lift top of display higher, then propped up. A photo of whole interior here would help (hard disk is top center). Used pliers holding T10 bit at right angle to unscrew hard disk holder. SSD installed loose (macOS and fan control app already loaded).
    David Menges - 回复
  6. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 6 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 6 中的图像 2,2
    • 将显示器从外壳上旋转到足以将LED背光电源电缆从LED驱动板上断开。
    • 将连接器从插槽(朝向iMac的底部边缘)拉出,同时按下锁定机构,断开LED背光电源电缆。
    This is real tricky it is fragile and you have to pull it along the logic board.
    John - 回复
    First push down on the edge of the connector closest to bottom edge of the iMac. This unlatches the locking mechanism at the top edge of the connector. Then gently wiggle the connector away from its socket.
    Oshoma Momoh - 回复
  7. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 7 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 7 中的图像 2,2
    • 显示数据线插头有一个线锁。 旋转塑料片使其朝上,使插头的锁脱开。 (不是拉那个标签。)
    • 将显示数据线直接从逻辑板上的插座中拔出。
    • 请勿抬起显示器的数据线,因为其插口非常脆弱。 将电缆平行于逻辑板的表面拉。
    This cable is very short, I would remove it before any of the others. First time I did this, I didn't realize this and this cable just popped out of it's socket. Luckily, the board wasn't damaged.
    maccentric - 回复
    i damaged my (step7) cable, and my iMac screen won't work, how to fix this?
    Ersan Rasubala - 回复
    I did the same thing. The pins are VERY easy to bend. I replaced it with a new cable from this company.
    http://www.macpalace.com/922-9497-cable-...
    Waiting for it to arrive.
    Michael -
    I wish this step was listed as a warning before lifting the monitor and as the first cable to undo. I broke it as it popped up and out, had to trash my Mac and I am stuck with a new hard drive.
    Frank1701a - 回复
    I followed the directions to a T and everything worked going back together. That cable in step 7 is delicate so one must be very careful.
    dustynnelson -
    Same problem for me. I damaged this cable and am ordering one now.
    This is a tough step so I would also suggest removing this cable first.
    lyleberman - 回复
    Yes, damaged mine too. It is better to take it out of the LCD and install it carefully on the logic board, then install it to the LCD.
    asle -
    Ok finally got the cable and was able to successfully finish the project.
    That video cable is ROUGH to install.
    lyleberman - 回复
    The same thing happened for me. That cable was by far the shortest and a slight pull of the display up caused the connector to come free. Luckily it wasn't damaged by this. It was pretty unclear to me how that connector fit in as well. It slides in and out parallel to the surface of the mother board, up towards the top of the iMac to unplug and down towards the bottom to plug in. I agree, if I were to do this repair again that is the first interior cable I would disconnect. Maybe a closeup of the cable plugged in and unplugged to show exactly how it engages and disengages would be good as well.
    danieljseta - 回复
    It is fine to remove the cable from the logic board when when you remove the screen. But when when assembling back together I found it better to take the LVDS cable out of the LCD and install it carefully on the logic board. Then connect it to the top of the LCD. Also the connector to the LCD is much more solid and not so easy to bend.
    asle - 回复
    This is by far the best way round to do this as trying to refit the cable to the logic board is a complete nightmare.
    Russ -
    I agree with asle, manipulating the display end of the cable would be easier - at least it cannot be any harder then manipulating the motherboard end.
    Jerry -
    well I did all t these steps and now the iMac won't turn on at all. I guess the big cable is not connected to the board as it used to... Mac is out of warranty so it's going out the door. RIP
    Gilbert Palau - 回复
    this thing is super fragile. i had to order a new one. i'd recommend removing the other end at the top of the display.
    m Burm - 回复
    this part is not complicated if you understand at first how the lock works.. remove the lock is easy, reassemble the cable and connect it is very problematic because the space to work is very tiny, but if you are carefully, it should be not a problem . try to see some videos from youtube first!
    Cristian Pizarro - 回复
    This totally blows.. If you want to do this correctly and not destroy your computer over this step, - OWC’s video will show you EXACTLy what to do with the display cable ..
    https://www.youtube.com/watch?annotation...
    Luis Garcia - 回复
    Don’t raise the display more than 3-4 inches. Pull the tape off the back of the display and unhook the cable from the display, instead of trying to remove it from the motherboard. As soon as I raised the display, the cable snapped loose. Ordered a new cable from Amazon. Am waiting to see if works ok.
    john - 回复
    The worst thing about the whole tear-down procedure, was the display data ribbon cable in this step. As others have noted, It popped out of its socket on the mother board while disconnecting the lcd. I didn’t get a chance to see exactly how it connected on to the moboard . I damaged the dainty and minute ribbon end while trying to re-connect it to the wrong side of the receptacle. Duh! I feel so stupid. :(
    I had to order a new ribbon cable ($14) . Luckily, i was able to plug new ribbon into the fragile moboard connector adequately, and then the lcd end, during re-assembly. This re-assembly step is made for a very small person with extremely small hands and big eyes (like someone out of Gulliver’s travels).
    Dan Packard - 回复
    2010 iMac SSD kit from OWC. Their video does not adequately explain the difficulty of re-installing the display port ribbon cable into the logic board. The best procedure would be to follow asle (see prior comment 8/11/15). The problem is exasperated by the fact that the plug into the LCD is covered in tape.
    Devere - 回复
    Why is this not step 5? By the time I lifted display, the cable had already come out. I think it damaged it.
    Greg Cox - 回复
    Got VERY lucky with my SSD replacement. Just leaning the display back popped the cable off the logic board, and I had a very difficult time reinstalling the screen. It might be that the wire bail wasn’t secured in the first place, or the machine has been opened up prior to my obtaining it. I eventually used a parts box to rest the LCD high enough to reinstall the cable. Agree that this should be the first cable to be disconnected and last to be reconnected. Perhaps disconnecting it from the LCD should be considered as a first step?
    phantom - 回复
  8. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 8 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 8 中的图像 2,2
    • 断开LCD热传感器电缆连接器与逻辑板上的插座的连接。
    • 如果您的风扇在完成后全速旋转,请检查此连接或硬盘驱动器的热传感器电缆。
    Be very careful - this connector very difficult to disconnect, and you have a high risk of pulling the cable pins out of the connect. If you have disconnected the 3 other cables, you can have a helper rotate the screen out of the way while you remove the hard drive.
    Brian Tsai - 回复
    I found this connector impossible to remove
    Anoop Sahal - 回复
    I also found this extremely difficult to remove. Tiny cable with a death grip. I tried using two spudgers, my fingernails, and walking it out. In the end, I used two spudgers and pried it up, using leverage from the clip to the right.
    Also, i recommend setting the iMac upright for this. I rested the screen on my chest while I dual wielded my spudgers.
    Alex Grayson - 回复
    eer ist zerbrochen! hoffe krieg ihn dann trotzdem wieder rein
    Peter Pawlowicz - 回复
    This was connector was impossible to remove. Like a previous commenter, I did this with the machine upright and with the LCD Panel resting on my upper chest. Ultimately, the pins pulled out of the socket! Once they were out, it was relatively easy to remove the socket. I completed the drive replacement, (installed a 1 TB SSD) and then replaced the pins in the socket and reassembled the machine. One mental error I made was I couldn’t remember the correct orientation for the Black and White wires in the socket. In looking at the photos here on iFixIt, it looks like I reversed their orientation. However, the machine seems to be running fine. I installed macos High Sierra and migrated my data from my old HD and the machine has been running for two days now. I would hate to have to go back in and remove the socket and reverse the wire orientation. Anyone have advise on this?
    jmaher - 回复
    In followup to my previous post, I launched TechTool Pro 9.6.1 and ran the Sensors Test. All Sensors tests were passed. These included:
    LCD Proximity, LCD Thermal Compensation 2, LCD Proximity, Thermal Compensation. Machine seems to be running fine.
    jmaher -
  9. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 9 中的图像 1,1
    • 小心地将显示器拉向iMac的顶部边缘,然后将其从外壳中取出,注意可能被卡住的任何电缆。
  10. iMac 因特尔 21.5" EMC 2389 硬盘更换, 硬盘: 步骤 10 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换, 硬盘: 步骤 10 中的图像 2,2
    • 朝向iMac顶部来从逻辑板的插座上拔下温度传感器
    I don't think this is necessary, I'd just leave it since you're removing the other end from the drive.
    maccentric - 回复
    Want to add a comment on this w/reference to HDD & thermal sensor. HDD used: WD1002FAEX - 1TB WD Black. Temperature sensor on this model iMac has a little tab/plastic protrusion, Apple HDD actually has specific opening for it. With this HDD/any after market WD HDD you should use small electrical wire cutters, and just cut off the offending piece of plastic from the iMac sensor. Insert it as specified, closest to SATA/PCB board, take a picture first before taking it out, and it works like a champ!
    MaximBorzov - 回复
    Sure enough, I had the same problem of the temperature sensor not fitting because of the plastic protrusion on the Apple connector. Instead of using a wire cutter to remove the protrusion, I filed it with a metal file (careful to place a rag cloth underneath, where all the filing dust would drop). It fit wonderfully after that.
    girlscandotoo -
    I am getting ready to swap out my wife's drive for an SSD. Since there are no moving parts do i need to be concerned with the temperature sensor?
    I picked up a 240GB PNY CS1200 Series drive. Its smaller than the original but she doesnt use that much anyways.
    Robert Hancock - 回复
  11. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 11 中的图像 1,1
    • 移走两颗将硬盘支架与外壳固定的9mm T10螺丝。
    T8 screw on my Mid-2010.
    rch - 回复
  12. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 12 中的图像 1,1
    • 轻轻地将硬盘驱动器从外壳中取出,然后将其从安装引脚上抬起,朝向iMac的顶部边缘。
    • 将硬盘驱动器从凹槽中取出时,请小心不要碰触到AirPort卡。
    Instead of trying to not hit the Airport card, spend 10 seconds to unscrew the one screw, pull it out of the socket and set it aside.
    maccentric - 回复
    WATCH IT! When pulling out the hard drive or putting in the new one, stay clear of the strong magnets that hold the glass pane in place. I was so focused on following those steps closely, and when I had the HDD clear I kind of relaxed a bit too much and – "CLONK" – the magnet pulled the HDD and ruined it.
    Roberting - 回复
    I have fitted a barracuda tb sata hdd ,i have partitioned the drive in d/utility .I have made a bootable us. stick containing os x and it says mac osx cannot be installed to your computer , even though itis displYed as verified in disk utility .......Plese help me !!!!!!
    therumourcastro - 回复
  13. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 13 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 13 中的图像 2,2
    • 径直从硬盘上的插座中拔出SATA数据和供电插头。
    Computer doesn’t see the new hard drive. Mid year 2010 iMac, #2389. Removed Seagate Barracuda 7200 500 gig drive. Installed Toshiba 7200, 1tb drive. Computer starts, screen lights but I get a ?. So I started in recovery mode but it doesn’t see a hard drive to load to. I have an external backup and it dies see that drive. Tried reinstalling the os over the internet but when it looks for a hard drive it doesn’t see one. The fan is running…starts off slowly but as timne goes by it gradyally speeds up.
    Any help is apprecioated
    Paul Theriault - 回复
  14. iMac 因特尔 21.5" EMC 2389 硬盘更换, 硬盘: 步骤 14 中的图像 1,2 iMac 因特尔 21.5" EMC 2389 硬盘更换, 硬盘: 步骤 14 中的图像 2,2
    • 断开热传感器电缆之前,请注意其方向。 以当前方向重新安装连接器非常重要,以免风扇全速运行。 如果更换硬盘驱动器上有多个引脚,请将连接器靠近SATA连接头并靠近PCB板。
    • 断开硬盘驱动器的硬盘驱动器热传感器电缆。
  15. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 15 中的图像 1,1
    • 卸下将上支架固定到硬盘驱动器的两颗T8 梅花螺丝。
    • 从硬盘驱动器上取下上支架。
  16. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 16 中的图像 1,1
    • 从硬盘的另一侧卸下两个T8 梅花支柱。
  17. iMac 因特尔 21.5" EMC 2389 硬盘更换: 步骤 17 中的图像 1,1
    • 小心地剥下连接在硬盘驱动器正面的一块EMI泡沫。
    • 不要忘记将其转移到新的硬盘上。
结论
按照本指南相反步骤来重新组装设备。
252等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
44条评论
I went through all the steps and now when I attempt to boot, I hear the apple chime, but I get nothing on screen.
I thought this might have to do with a loose cord, but when I reattached the suspect cord (the display data cable) it did not resolve the problem.
Anyone have any ideas as to what could be causing the display to malfunction?
Monty - 回复
I had this problem as well, caused by a small cable coming from the display. It is a Sync Cable with a small 2 Pin Molex connector, and it popped up and got hidden when I removed the display, which caused me to forget to re-attach it during reassembly.
capone99 -
Question for capone99: where did this cable come from? Was it one of the five specified for unplugging in this guide? Or are you saying it came loose by itself during installation?
lewisthegreat -
Did anyone ever solve this? Having the same issue.
rowanevan -
In step 14, the Apple connector for the hard drive has a locking mechanise that doesn't fit most replacement hard drives. I got an identical hard drive that doesn't have a provision for the connector. A little bit of shaving or filing of the plastic connector did the trick.
mercadoamiel - 回复
I want to use a (WD20EARX) 2TB hard drive which does NOT have a socket matching the old hard drive for the thermal sensor plug, but rather 8 jumper pins. Can I use this drive as a replacement, and if so what do I do about the thermal sensor?
Robert - 回复
I replaced my hard drive Samsung 1TB. I put a Seagate Barracuda 1TB instead.
I had the problem of thermal sensor that was not adapted to Seagate. I cut it in half cutter, I connect and everything works perfectly.
castusfrancois - 回复
And, finally, additional tool which was super awesome: FLASHLIGHT. Small, flashlight is awesome when just examining the internals prior to removal/especially if you have a way to prop up the LCD panel, since it will cover the main board, and you need some idea as to where what is.
MaximBorzov - 回复
Thanx everybody! I`m new hear & need all the help I can get!
vpkc15 - 回复
This was a great guide and worked perfectly for me. Replaced my non-working 500GB for 1TB new drive. After the installing got an error "folder with question mark". Took it to the apple store had them install a new OS X for free and it is working great now......
singhaviation - 回复
Hi Tim , did you resolve the issue .I used internet recovery n it still fails
What I did was:
- Substitute the broken internal hdd with a new one (WD to Segate)
- Change the disk bay to an SSD
Problems I haced:
1) thermal sensor between wd and segate. My fix was to open up the plastic piece that connects to the HDD and separate the cables. Then I taped each cable with isolating material and connected the cables to the bins by hand (praying they would not pop out before I was finished). Actually I noticed that the tape was filling the space in the cavity, making the cables stay in place: fans not spinning crazy.
2) The SSD adapter I bought was a little bit weird and would not fit in the black plastic case of the CD drive. My fix: polish irregularities away from the plastic support. In the end it worked and the drive is now attached
3) Screen connection cable. This one was THE WORST. The cable is really, really delicate and by trying to connect it back after I was finished I broke it in three different ways. Here I suggest PATIENCE and delicacy! I still got it to work though :)
Christian Dallago - 回复
Christian, for the thermal sensor, how did you know which bins / cables to put together? what was the number / configuration of pins on your new drive? any insight you might have here would be appreciated
geemac -
Excellent guide. Managed to swop out my hdd for a ssd using this guide. The ribbon cable in step 7 is one of the more difficult steps to deal with. Be careful not to break the socket.
howeikeong - 回复
Excellent guide. Managed to swop out my hdd with a ssd using this guide. The cable in step 7 has to be carefully dealt with though.
howeikeong - 回复
1/5
I'll always choose the DIY option as I don't like paying for labour. This time (with virtually zero experience of taking anything apart, never mind my precious iMac) I wondered if I'd bitten off more than I could chew. I spent a good bit of time watching videos and reading walk through guides before attempting a HDD - SSD replacement. This guide was one of the best and I feel I owe an account of my experience to anyone thinking of doing this.
Removing the glass was as easy as I expected it to be. I used 'the straw' method (mentioned in the comments here) to remove the screws, avoiding magnet attacks. When in the straw, you can quickly whip out the screws using the magnetic tip of your screwdriver. 2-3 were claimed when screws or straws slipped although it was easy to get them back with tweezers.
shawfamily53 - 回复
2/5
After peeking under the LCD I was alarmed to see how short the vertical sync cable was in mine (4-5 cm from top to bottom). It turned out to be quite a long cable but I had to prize some of it away from some adhesive/adhesive tape towards the bottom.
The LED backlight power cable was very stiff to remove. I had to be careful not to force it even when pressing quite hard to unlock (might have been me?).
Next up, the dreaded display data cable. No problems disconnecting this although it would later give me a big headache.
I found the LCD sensor very fiddly. I have pretty small hands yet, fingers/finger nails seem inadequate for such a small cable and socket. Of all the cables I removed this was the one I expected to have damaged. I pulled on the cable through frustration as I couldn't get a hold of the plastic plug.
shawfamily53 - 回复
3/5
Display and HD temp sensor came out without any bother.
My dead HD also came out without too much trouble although the SATA and thermal sensor cables were quite stiff.
I should mention (at this point) that I had decided to replace my old HHD with an SSD.
I therefore decided to completely remove the thermal sensor cable with a view to using 'fan control' software after replacement. At first, I assumed that the drive would be facing upwards and consequently put the sponge from my old HD on the outside of the 2.5 - 3.5 mounting bracket I'd bought. This also lead to me putting the upper mounting bracket on the wrong side when in actual fact, the mounting bracket would fix back in with the new SSD hanging upside down and sponge on the drive itself (not that this matters. It will ultimately be on it's side when fitted anyway).
With new bracket in place, the SATA cables were a little bit short of where the plugs were. The plugs needed forcing in to line with the sockets. Some slight manipulation required here.
shawfamily53 - 回复
4/5
Complications arose when connecting back up (the part that isn't in any guides).
Once again, the LCD sensor cable was tricky fuelling concern of possible damage.
The display data cable cost me a good chunk of afternoon. Without the iMac being upright on it's stand (OWC method of process) it's so difficult to see where this wafer thin cable should connect. I tried moving various props to hold the LCD at a different height and angle as well as moving an LED spotlight about (red hot). The Airport card also obstructs any clear view of both plug and socket. On top of that there's the locking tab to get back in place without touching the logic board.
Some time later, I was fairly (but not 100%) sure that it was locked in place.
After plugging in the other cables, keeping the screen and glass dust free was also quite challenging.
shawfamily53 - 回复
5/5
So to the moment of truth. Booting up in recovery mode.
I heard the start up chime but the screen remained black. Back on the Internet to check diagnostics (noticing comments at the top of this thread). On further inspection after taking my Mac apart a 2nd time (in a fraction of time it took originally) I noticed that my nemesis (the display data cable) had either come out on reassembly, disassembly or had not been plugged in correctly in the first place. Several slow mo web videos later I finally nailed it.
I'm currently running a 'Time Machine' backup (6 hours with the fan running at full tilt) but am hopefully on track.
Will report back if there are issues. No news will be good news.
shawfamily53 - 回复
I found when replacing hard drive the most difficult task is to replug the Display data cable back into the logic board. There is just so little room to work, I damaged the data cable plug contacts and the display would not work. For me work around was to order replacement data cable and install first on logic board before trying to mount and connect other display cables. And installing data cable to Display socket last. This end is larger and more robust up near the top edge of the Display giving one much more room to work.
jackshrawder - 回复
I successfully completed this repair. Went from 500GB Seagate to 1TB WD Blue.
Problems I had are limited to the thermal connector would not fit the hard drive I bought. I'm pretty sure the pins on my new drive are for an 8-pin thermal instead of a 4-pin, and I just left it unplugged. The fans spin at full speed now, but that's hardly a deal-breaker.
Corvallis Computer - 回复
I am about to replace my original HD with 4TB Seagate SHDD. My goal was to clone my SHDD before installing. When connecting my SHDD to USB port, my SHDD cannot be found via DiskUtility. The cabling is correct since alternative HD (low density) can be found. Any suggestions? I am using Yosemite (10.10.5).
kvanwinckel - 回复
I ran into the cable temp sensor issue when I replaced a Western Digital (8-pin connector) with a Seagate SSHD (4-pin connector). To resolve it I purchased the OWC temp sensor kit for 2009-2010 iMacs. Unfortunately it did not work with the sensor installed on top of the spindle. The problem is that there is not of clearance and it ends up touching the back on the display and when the screws are reinstalled the computer will not turn on.
OWC's product almost works as described, but is not the best solution. I recommend opening your iMac up to see what type of drive you have and getting the official temp sensor adapter cable from and Apple part supplier (on eBay too). They are around $20 and there is one for each drive manufacturer. The easiest solution is to buy a drive from the same manufacturer and it most likely will have the same sensor plug. I know that some mods can be made to the cable end to get it to fit, but I don't see how the 8-pin plug could be modified to be put into a 4-pin jack.
jehayes68 - 回复
Replaced the 500GB hard drive to a 2TB hard drive, was gonna put a SSD in optical bay as well but ordered a mSATA drive instead of SATA by accident. Overall was pretty easy but very painful trying to reconnect the Display cord. All in all... I've worked on my now 4th apple computer... and 4th computer of all time... and if I can do it you can do it, Make sure your new HARD Drive is the same brand as the one that comes with macbook. I just had to sand down the connection for thermal sensor a little but otherwise it fits without hassle.
scottmcintyre - 回复
A year after 'war and peace' (above) and all is well. SSD works a dream. Have been using 'Fan Control' from day 1 with no issues to date.
shawfamily53 - 回复
I did this around 3 years ago. There's a problem when connecting the new hard drive with the hard drive cable. I'm using a 500GB WD Blue and there seems to be a "tooth" on the iMac connector that won't fit the WD Blue. The only solution was to file off that small plastic tooth. I also didn't need suction cups to remove the glass panel. I accidentally discovered another way, when I was running my finger nail around the seams, it popped up. I wouldn't suggest it though.
mercadoamiel - 回复
As much as I appreciate IFixIt guides this one falls short of their usual high standard.
There are several omissions that can lead to a failed repair.
I wanted to say much more but it would not fit on this page, so briefly:
Failed to mention importance of opening system to determine original brand of drive installed (Seagate, Western Digital, Samsung).
Failed to mention need to get same brand so that thermal sensor could be attached to new drive.
Failed to mention without thermal sensor attached fan will continuously run at full speed very loudly.
Failed to mention need to trim off polarization tab from thermal sensor connector on Western Digital drives.
Failed to mention need to trim 8 pin thermal sensor block on Western Digital drives down to 6 pins so that sensor can be flipped yet keep thermal sensor wires connected to the second set of pins closest to the SATA connector.
Failed to mention that lifting the LCD slowly as cables can be glued in place and need to be freed up or risk damaging.
And more...
X Gempler - 回复
I replaced my 2011 iMac WD HD with a WD, it might be a different model…..I used OWC for the process, they didn't say anything about the thermal sensor except to use their harness, which I could not fit.
And when I took the old HD out, I did not see the cable above they are showing at all? any ideas? Fans seem to be running a bit more……also I did not have the little foam for the back-side, will that hurt anything?
My TechTool Pro says all is well.
BTW-if you get the blinking folder, go online and get the tools to format disc and install your OS. (Disk Repair)
the guys at apple couldn't tell tell me that and I spent several hours looking at a blinking folder!
jaa - 回复
My iMac …mid year 2010, 2389. I had a failed Seagate Barracuda, 7200.12 , 500 Gbyte. I installed a Toshiba 1TB 7200 drive. Now the computer starts (chime sounds) and I get a ? . I plugged in my backup Seagate and the computer see it but restoring with time machine fails. I started the computer in Internet recovery mode and it attempts to load the OS but when I get to the window where it asks what drive to load it to, it doesn’t see a hard drive. Regarding the fan, it seems to work correctly as far as I can tell. It starts off running slowly and as the machine runs longer the fan speeds up.
So can someone tell me what to do to get the computer to “see” the new drive? ( I selected this drive from the iFixit suggested list of drives.)
Paul
Paul Theriault - 回复
Hi, I know I’m 3 years late, but you need to go into Disk Utility in Mac, and then format the drive that you putted in where the Optical Drive is, and then it should detect it, and therefore, you can use it for more storage.
- PS5iscool - -
Okay, so I got it running. The trick in my case was to start it with the “Option” key method. Put the external drive with the backup, or a thumb drive with the image into the USB port and start the machine while holding the option key and proceed from there. Walked through the steps to partition and mount the drive and then load it with the operating system. Takes a while but worked a treat. Then after the operating system was happy I used Time Machine to get everything from the old drive transferred to the new drive. Also down loaded “Macs Fan Control” to calm the furious fan.
Hope this helps someone
Regards
Paul Theriault
Paul Theriault - 回复
How will I install a new OS X SYSTEM on a new HD ? on my iMac
Henery - 回复
As the computer restarts, hold down the Command (⌘) – Option (⌥) – R combination immediately upon hearing the startup chime.
Hold the keys until the animated globe appears on the screen. “Starting Internet Recovery,” the message reads. ”This may take a while.”
A Wi-Fi menu appears. Internet Recovery needs an Internet connection to load the recovery tools from Apple’s servers. Click the menu to display the available Wi-Fi networks, and then select one to connect to.
Tip: If you’re connected to the Internet using Ethernet, you don’t have to connect to a Wi-Fi network during Internet Recovery.
If this isn’t an open Wi-Fi network, you’ll be asked to type in your password. Press Enter on the keyboard or click the checkmark symbol to continue.
After your Mac has connected to the Wi-Fi network, it’ll download a recovery system image from Apple’s servers and start from it, giving you access to the recovery tools.
This may take anywhere from a couple of minutes to up to an hour, or longer.
Choose the option Install OS X
sternbergbob -
How will I restore my OS X system on the new HD of my iMac 21”
Henery - 回复
I have replaced the HD , now Have to install OS X, What I do ?
Henery - 回复
Swapping out the hard disk was ok. What happened after this:
imac‘s display stayed dark although Mac was working and booting up (fans running normally and hard disk working i could heat that) had no choice to shut down the hard way, i.e. holding power button
I suspected the displayport cable wasn’t properly in its socket and it wasn’t. Fixed that.
But then: imac won’t turn on. Tried SMC and NVRAM resets. First fans came back and then chime. But still the display is dark. Chimes comes but This time hard disk seems to do nothing at all.
Why my iMac wasn’t turning on I found out the next morning by pure luck: when it’s running and I’m tilting it back it shuts down as if something inside isn’t working only if Mac’s in a particular angle.
So question: anything I missed here or something defective?
Dong Hun Lee - 回复
Alright, fixed it. Got me a new internal Displayport cable. Somehow i‘ve must have broken it.
Dong Hun Lee -
Mid-2010 with stock iMac WD Caviar Blue 500 GB HDD failed after 9 years. I replaced it with a 1TB SSD using nothing more than Electrical Tape and a 15 cent transistor.
Reading the full set of instructions first was useful in discovering that the LCD panel has short cable lengths - A flashlight, and a plastic knife were majorly useful tools. The knife helped with gently removing or pushing the pins as required.
The HDD was easily removed. I kept the metal bar which held the original HDD and used Electrical Tape to mechanically fasten the SSD to the bar.
Using the 2N3904 transistor I pushed the Emitter pin into the grey wire pin of the thermal sensor cable and both Base + Collector pins into the black wire pin. (Original solution by Alexandre on iFixit).
I tested the setup by powering up the computer connected to an external display. Everything worked as expected.
Closed the computer back up, cleaned the LCD with crumpled newspaper (it works really well) and booted from a secondary SSD in the DVD slot.
Awesome!!
James McDouall - 回复
The thermal sensor cable shown is incorrect. My original HD has an 8-pin connector, where the HD recommended by iFixIt has only 4 pins. Not sure how I’m gonna fix this issue.
John Blunda - 回复
Se non collego il sensore di temperatura cosa sucecde?
Seth Gecko - 回复
La ventola girerà sempre alla massima velocità. È possibile risolvere il problema controllando la velocità della ventola utilizzando il software.
The fan will spin at full speed all the time. You can fix the problem by controlling the fan speed using software.
Arthur Shi -
I tried turning on my iMac and the screen is blank with fans running at full speed, which I understand to be an issue with the thermal sensor.
However, I have made sure that all the cables are firmly attached before attempting to run the iMac.
Does anyone have an idea as to which other factors could be the source of this issue?
P.S. I only took it apart as the iMac randomly shut down one day and couldn’t be switched on, my assumption is that it overheated and did that to protect itself.
nuuuitsjdragon - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 138
过去 30 天: 706
总计 307,694
