跳转到主内容
加入维修社区 - 创建账户
iHome iPL8 Screen Replacement
你所需要的
  1. iHome iPL8 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
    询问修复机器人
    添加评论
  2. iHome iPL8 Screen Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
    询问修复机器人
    添加评论
  3. iHome iPL8 Screen Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
    询问修复机器人
    添加评论
  4. iHome iPL8 Screen Replacement: 步骤 4 中的图像 1,2 iHome iPL8 Screen Replacement: 步骤 4 中的图像 2,2
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
    询问修复机器人
    添加评论
  5. iHome iPL8 Screen Replacement, Lightning Connector: 步骤 5 中的图像 1,1
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
    询问修复机器人
    添加评论
  6. iHome iPL8 Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
    询问修复机器人
    添加评论
  7. iHome iPL8 Screen Replacement: 步骤 7 中的图像 1,2 iHome iPL8 Screen Replacement: 步骤 7 中的图像 2,2
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
    询问修复机器人
    添加评论
  8. iHome iPL8 Screen Replacement: 步骤 8 中的图像 1,2 iHome iPL8 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
    询问修复机器人
    添加评论
  9. iHome iPL8 Screen Replacement: 步骤 9 中的图像 1,3 iHome iPL8 Screen Replacement: 步骤 9 中的图像 2,3 iHome iPL8 Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
    询问修复机器人
    添加评论
  10. iHome iPL8 Screen Replacement, Screen: 步骤 10 中的图像 1,1
    • Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
    • Remove the four 2.5 mm Phillips #1 screws on the green panel.
    • Flip the green panel to reveal the front of the screen.
    询问修复机器人
    添加评论
  11. iHome iPL8 Screen Replacement: 步骤 11 中的图像 1,2 iHome iPL8 Screen Replacement: 步骤 11 中的图像 2,2
    • Locate the transparent, rectangular plastic screen cover.
    • Gently lift the cover off.
    • The screen is now revealed. Replace the screen with a functioning one.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Chen Zhong
于02/05/19注册
569 声望
创作了4篇指南
团队
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019 的会员
UCD-LORE-W19S18G5
3 名成员
创作了8篇指南
1指南评论
Hi, I have one iHome iBN20 that needs to replace the screen too.
Please guide me to open up the casing.
Thank you.
Chan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 23
总计 441
