跳转到主内容
加入维修社区 - 创建账户
iHome iD95 iPod Adapter Replacement
你所需要的
    1. iHome iD95 iPod Adapter Replacement, Backup Battery: 步骤 1 中的图像 1,1
      • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
      • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
      询问修复机器人
      添加评论
    2. iHome iD95 iPod Adapter Replacement: 步骤 2 中的图像 1,1
      • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    3. iHome iD95 iPod Adapter Replacement: 步骤 3 中的图像 1,1
      • Use a plastic opening tool to take out the backup battery.
      询问修复机器人
      添加评论
    1. iHome iD95 iPod Adapter Replacement, Bottom Cover: 步骤 4 中的图像 1,1
      • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. iHome iD95 iPod Adapter Replacement: 步骤 5 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 5 中的图像 2,2
      • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
      • Insert a plastic opening tool between the edge of the bottom cover and the main body.
      • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
      • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
      询问修复机器人
      添加评论
    3. iHome iD95 iPod Adapter Replacement: 步骤 6 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 6 中的图像 2,2
      • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
      • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
      • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
      询问修复机器人
      添加评论
    4. iHome iD95 iPod Adapter Replacement: 步骤 7 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 7 中的图像 2,2
      • Apply the same techniques from the previous step to remove the remaining side panel.
      询问修复机器人
      添加评论
    5. iHome iD95 iPod Adapter Replacement: 步骤 8 中的图像 1,3 iHome iD95 iPod Adapter Replacement: 步骤 8 中的图像 2,3 iHome iD95 iPod Adapter Replacement: 步骤 8 中的图像 3,3
      • Locate the two plastic clips holding the bottom and back cover together.
      • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
      • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
      • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
      • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
      询问修复机器人
      添加评论
    6. iHome iD95 iPod Adapter Replacement: 步骤 9 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 9 中的图像 2,2
      • Use the same steps to remove the remaining clip.
      • The bottom cover is still connected to the motherboard by wiring.
      询问修复机器人
      添加评论
    7. iHome iD95 iPod Adapter Replacement: 步骤 10 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 10 中的图像 2,2
      • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
      • Don't pull the wires. Take your time using a plastic opening tool.
      询问修复机器人
      添加评论
    1. iHome iD95 iPod Adapter Replacement, Speakers: 步骤 11 中的图像 1,1
      • Take out four 14 mm screws using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. iHome iD95 iPod Adapter Replacement: 步骤 12 中的图像 1,3 iHome iD95 iPod Adapter Replacement: 步骤 12 中的图像 2,3 iHome iD95 iPod Adapter Replacement: 步骤 12 中的图像 3,3
      • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
      • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
      询问修复机器人
      添加评论
    3. iHome iD95 iPod Adapter Replacement: 步骤 13 中的图像 1,1
      • Lift and remove both speakers.
      询问修复机器人
      添加评论
    1. iHome iD95 iPod Adapter Replacement, iPod Adapter: 步骤 14 中的图像 1,2 iHome iD95 iPod Adapter Replacement, iPod Adapter: 步骤 14 中的图像 2,2
      • Flip the logic board over.
      • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
      询问修复机器人
      添加评论
    2. iHome iD95 iPod Adapter Replacement: 步骤 15 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 15 中的图像 2,2
      • Remove two 4 mm-head 12 mm-length screws using a Phillips #1 screwdriver.
      • Pull the iPod adapter from the top cover.
      询问修复机器人
      添加评论
    3. iHome iD95 iPod Adapter Replacement: 步骤 16 中的图像 1,2 iHome iD95 iPod Adapter Replacement: 步骤 16 中的图像 2,2
      • Use a Phillips #1 screwdriver to take out the two, 12 mm-length 4 mm-head, screws holding the iPod adapter to its casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Vincent Chan
于04/18/13注册
19 声望
创作了6篇指南
团队
Cal Poly, Team 12-37, Amido Spring 2013 Cal Poly, Team 12-37, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G37
4 名成员
创作了21篇指南
1指南评论
Great article. I have an iHome iDL95 and would like to swap the Lightening adapter with a 30-pin adapter so that I can utilize my iPod 5.5 Classic. Is this possible? If so, where do I obtain the required 30-pin replacement adapter? Thanks.
P. Matt - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 2,287
