跳转到主内容
加入维修社区 - 创建账户
iHome IBT16 Power Switch Replacement
你所需要的
    1. iHome IBT16 Power Switch Replacement, Base Plate: 步骤 1 中的图像 1,2 iHome IBT16 Power Switch Replacement, Base Plate: 步骤 1 中的图像 2,2
      • Make sure to flip the device over to get into the correct orientation
      • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
      • Make sure to keep these screws in a safe location so you don't lose them
      询问修复机器人
      添加评论
    2. iHome IBT16 Power Switch Replacement: 步骤 2 中的图像 1,2 iHome IBT16 Power Switch Replacement: 步骤 2 中的图像 2,2
      • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
      • Using a lever like motion, push the opening tool down thus lifting the plate
      • You will need to use your fingers to lift the base plate off the main body of the device
      • The motherboard is directly underneath the base plate
      询问修复机器人
      添加评论
    1. iHome IBT16 Power Switch Replacement, Power Switch: 步骤 3 中的图像 1,2 iHome IBT16 Power Switch Replacement, Power Switch: 步骤 3 中的图像 2,2
      • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
      • Don't misplace the screws! Keep them in a safe place while working on the device
      • Make sure to ground yourself prior to continuing at this point
      询问修复机器人
      添加评论
    2. iHome IBT16 Power Switch Replacement: 步骤 4 中的图像 1,1
      • Using the plastic opening tool, pull the motherboard out of the casing
      • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
      询问修复机器人
      添加评论
    3. iHome IBT16 Power Switch Replacement: 步骤 5 中的图像 1,2 iHome IBT16 Power Switch Replacement: 步骤 5 中的图像 2,2
      • Desolder the 10 points holding the power switch to the motherboard
      • Once complete, simply remove the switch from the board
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Ryan Edwards
于03/21/17注册
331 声望
创作了3篇指南
团队
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017 的会员
UMASSD-BOTVIN-S17S3G6
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,057
