简介
This guide will teach you how to correctly remove the battery for this device.
你所需要的
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Inside the iHome remove the two 10mm silver Phillips screws that are on the motherboard.
To put it all back together, solder the battery wires to the correct solder joints. Then place the battery back under the motherboard and screw the motherboard back on. After that put the face plate back on, and screw on the face plate
另外一个人完成了本指南。
