跳转到主内容
加入维修社区 - 创建账户
iFit Act Battery Replacement
你所需要的
    1. iFit Act Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Hold the iFit band in both hands, with your thumbs on either side of the tracker pod at the center of the wristband.
      询问修复机器人
      添加评论
    2. iFit Act Battery Replacement: 步骤 2 中的图像 1,1
      • Using your index finger, gently push the tracker pod out of the wristband. It may help to do this over a table or other surface so the tracker pod doesn’t fall on the floor and break.
      询问修复机器人
      添加评论
    3. iFit Act Battery Replacement: 步骤 3 中的图像 1,1
      • Once the tracker pod is freed from the wristband, remove the back of the tracker pod using the plastic opening tool. The tool’s curved edge should be pointed toward the back of the device to avoid scratching the front display.
      询问修复机器人
      添加评论
    4. iFit Act Battery Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Using the curved metal precision tweezers, gently lift the battery out of the tracker pod.
      询问修复机器人
      添加评论
    5. iFit Act Battery Replacement: 步骤 5 中的图像 1,1
      • Place the new battery in the tracker pod. Make sure the positive side of the battery is face down in the cavity of the tracker pod.
      询问修复机器人
      添加评论
    6. iFit Act Battery Replacement: 步骤 6 中的图像 1,1
      • To close the tracker pod, place the top and bottom pieces between fingers as shown and snap them together.
      询问修复机器人
      添加评论
结论
To assemble this device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
University of Maine, Team 1-1, Diaz Fall 2015 University of Maine, Team 1-1, Diaz Fall 2015 的会员
UMAINE-DIAZ-F15S1G1
4 名成员
创作了1篇指南
2指南评论
The directions state that battery CR2032 is the battery for the ifit.act. I purchased this battery and it does not fit. Where can I get the battery that is compatible with ifit.act?
Revice Fisher - 回复 分享
The original battery should have identifying markings on the top so you can purchase an identical replacement. A standard CR 2032 coin cell battery is what’s specified by the manufacturer.
Jeff Suovanen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 50
总计 16,396
