跳转到主内容
加入维修社区 - 创建账户
iBook G3 Clamshell Keyboard Replacement
你所需要的
    1. iBook G3 Clamshell Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      询问修复机器人
      添加评论
    1. iBook G3 Clamshell Keyboard Replacement, Airport Card: 步骤 2 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      询问修复机器人
      添加评论
    2. iBook G3 Clamshell Keyboard Replacement: 步骤 3 中的图像 1,1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      添加评论
    3. iBook G3 Clamshell Keyboard Replacement: 步骤 4 中的图像 1,1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      询问修复机器人
      添加评论
    1. iBook G3 Clamshell Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
      • Remove the two Phillips screws that secure the RAM shield.
      询问修复机器人
      添加评论
    2. iBook G3 Clamshell Keyboard Replacement: 步骤 6 中的图像 1,1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      询问修复机器人
      添加评论
    3. iBook G3 Clamshell Keyboard Replacement: 步骤 7 中的图像 1,1
      • Pull up the keyboard connector cable by its clear plastic loop.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
1指南评论
I was worried about replacing the key board having never worked on a laptop before, your guide was a great help! Thank you, Dave
dave - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 53
总计 10,252
