跳转到主内容
加入维修社区 - 创建账户
iBook G3 12" Top Shield Replacement
你所需要的
    1. iBook G3 12" Top Shield Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      添加评论
    1. iBook G3 12" Top Shield Replacement, Keyboard: 步骤 2 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      询问修复机器人
      添加评论
    2. iBook G3 12" Top Shield Replacement: 步骤 3 中的图像 1,1
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      询问修复机器人
      添加评论
    3. iBook G3 12" Top Shield Replacement: 步骤 4 中的图像 1,1
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      询问修复机器人
      添加评论
    4. iBook G3 12" Top Shield Replacement: 步骤 5 中的图像 1,1
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      询问修复机器人
      添加评论
    5. iBook G3 12" Top Shield Replacement: 步骤 6 中的图像 1,1
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      询问修复机器人
      添加评论
    6. iBook G3 12" Top Shield Replacement: 步骤 7 中的图像 1,1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      询问修复机器人
      添加评论
    7. iBook G3 12" Top Shield Replacement: 步骤 8 中的图像 1,1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      添加评论
    1. iBook G3 12" Top Shield Replacement, Lower Case: 步骤 9 中的图像 1,1
      • Your laptop should look approximately like this.
      添加评论
    2. iBook G3 12" Top Shield Replacement: 步骤 10 中的图像 1,1
      • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
      询问修复机器人
      添加评论
    3. iBook G3 12" Top Shield Replacement: 步骤 11 中的图像 1,1
      • Remove the three 5.2 mm newly-revealed Phillips screws.
      添加评论
    4. iBook G3 12" Top Shield Replacement: 步骤 12 中的图像 1,1
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
      询问修复机器人
      添加评论
    5. iBook G3 12" Top Shield Replacement: 步骤 13 中的图像 1,1
      • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
      添加评论
    6. iBook G3 12" Top Shield Replacement: 步骤 14 中的图像 1,1
      • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
      询问修复机器人
      添加评论
    7. iBook G3 12" Top Shield Replacement: 步骤 15 中的图像 1,1
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
      询问修复机器人
      添加评论
    8. iBook G3 12" Top Shield Replacement: 步骤 16 中的图像 1,1
      • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
      添加评论
    9. iBook G3 12" Top Shield Replacement: 步骤 17 中的图像 1,1
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
      询问修复机器人
      添加评论
    10. iBook G3 12" Top Shield Replacement: 步骤 18 中的图像 1,1
      • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
      添加评论
    11. iBook G3 12" Top Shield Replacement: 步骤 19 中的图像 1,1
      • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
      添加评论
    12. iBook G3 12" Top Shield Replacement: 步骤 20 中的图像 1,1
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
      添加评论
    1. iBook G3 12" Top Shield Replacement, Upper Case: 步骤 21 中的图像 1,1
      • Remove the following 4 screws on the bottom of the computer:
      • Two 3 mm Phillips from the left side of the computer.
      • One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
      • One 14.2 mm Phillips near the front, right corner.
      添加评论
    2. iBook G3 12" Top Shield Replacement: 步骤 22 中的图像 1,1
      • Use a straightened paperclip to open the optical drive tray.
      添加评论
    3. iBook G3 12" Top Shield Replacement: 步骤 23 中的图像 1,1
      • Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
      添加评论
    4. iBook G3 12" Top Shield Replacement: 步骤 24 中的图像 1,1
      • Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
      添加评论
    5. iBook G3 12" Top Shield Replacement: 步骤 25 中的图像 1,1
      在这个步骤中使用的工具:
      • Turn over the computer and open it.
      • Use tweezers (or a refrigerator magnet) to remove the magnet covering a Phillips screw near the middle of the computer.
      添加评论
    6. iBook G3 12" Top Shield Replacement: 步骤 26 中的图像 1,1
      • Remove the following 4 screws on the edges of the keyboard area.
      • One 4.5 mm Phillips underneath where the magnet was.
      • Three 6 mm Phillips in plastic depressions.
      添加评论
    7. iBook G3 12" Top Shield Replacement: 步骤 27 中的图像 1,1
      • Peel up the foil tape covering the speaker cable near the ports.
      询问修复机器人
      添加评论
    8. iBook G3 12" Top Shield Replacement: 步骤 28 中的图像 1,1
      • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      添加评论
    9. iBook G3 12" Top Shield Replacement: 步骤 29 中的图像 1,1
      • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
      • Slide the orange trackpad ribbon out of the connector.
      询问修复机器人
      添加评论
    10. iBook G3 12" Top Shield Replacement: 步骤 30 中的图像 1,1
      • Before you can jerk the upper case off with joy, you must disconnect both the blue and white power cable and red and black speaker cable as described in the next steps.
      • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
      • There may be a thin metal bar fastened to the upper case by the two screws on either side of the optical drive. This bar provides rigidity around the optical drive; don't forget it when reassembling.
      添加评论
    11. iBook G3 12" Top Shield Replacement: 步骤 31 中的图像 1,1
      • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
      • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
      添加评论
    12. iBook G3 12" Top Shield Replacement: 步骤 32 中的图像 1,1
      • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
      添加评论
    13. iBook G3 12" Top Shield Replacement: 步骤 33 中的图像 1,1
      • There is a magnet that allows the computer to detect when the laptop is closed. If this magnet is not present your computer will not automatically go to sleep. Be sure the magnet is in the position indicated.
      添加评论
    1. iBook G3 12" Top Shield Replacement, Top Shield: 步骤 34 中的图像 1,1
      添加评论
    2. iBook G3 12" Top Shield Replacement: 步骤 35 中的图像 1,1
      • Remove the following 14 screws (some models may be missing a couple of screws):
      • One 2.5 mm Phillips.
      • Six 3.5 mm Phillips.
      • One 4.5 mm Phillips near the sleep light with a small shaft.
      • Two 4.5 mm Phillips with larger shafts.
      • Four 5 mm Phillips
      • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
      添加评论
    3. iBook G3 12" Top Shield Replacement: 步骤 36 中的图像 1,1
      • Peel back three strips of yellow tape in the bottom left corner.
      • Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
      添加评论
    4. iBook G3 12" Top Shield Replacement: 步骤 37 中的图像 1,1
      • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 37
总计 6,666
