跳转到主内容
加入维修社区 - 创建账户
iBook G3 12" RAM Replacement
你所需要的
  1. iBook G3 12" RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    添加评论
  2. iBook G3 12" RAM Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    询问修复机器人
    添加评论
  3. iBook G3 12" RAM Replacement: 步骤 3 中的图像 1,1
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    询问修复机器人
    添加评论
  4. iBook G3 12" RAM Replacement: 步骤 4 中的图像 1,1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    询问修复机器人
    添加评论
  5. iBook G3 12" RAM Replacement: 步骤 5 中的图像 1,1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    询问修复机器人
    添加评论
  6. iBook G3 12" RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    询问修复机器人
    添加评论
  7. iBook G3 12" RAM Replacement: 步骤 7 中的图像 1,1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    询问修复机器人
    添加评论
  8. iBook G3 12" RAM Replacement: 步骤 8 中的图像 1,1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    添加评论
  9. iBook G3 12" RAM Replacement, RAM: 步骤 9 中的图像 1,1
    • Your laptop should look approximately like this.
    询问修复机器人
    添加评论
  10. iBook G3 12" RAM Replacement: 步骤 10 中的图像 1,1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
47等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 52
总计 34,685
